Zemismart roller motor ZM25R1 missing controls (ZHA)
Hi!
Over my testing with different tubular/roller motors I went over a few models from Zemismart (Wifi AC, Zigbee battery and last with a newer model that is zigbee AC).
The latest i mentioned and bought is the ZM25R1
It looks nice and I just installed it. It works fine with the remote and it is bind to ZHA. However, there are no controls. I guess driver is not yet ready for ZHA?
Is there any way I can request it to be covered? Is there any way I can help in doing that?
I really want to go with this model. I want something that is zigbee and i want to get rid of batteries version. I have plugs on all curtains and batteries to feed the house if electricity goes out. So, having batteries on the motors, and have to charge them is not nice (to many to charge if I go all in with that method).
Also, my tubes are 32mm, which reduce the options I can use. This is for 38mm, but I saw on photos tube seems to be thinner, it fits well on tubes after creating custom crowns / rings with printer.
Hello, I am having this exact same issue and its driving me up the wall. Have you found any fixes
Hi, sorry, just saw the msg. Isn’t this working yet?
I created a custom driver to make it work and also committed the update to the main ZHA repository with the fix for it.
Although, to be honest, I never removed the custom driver to double-check it was really published.
Is it the same device TZE200_1vxgqfba?
My ZM25R1 comes up as TZE200_wdfurkoa. No entities showing
Hi @kdober and @mynameisplayer,
Have you succeeded with getting the ZM25-R1 to work with ZHA?
