Zemismart Roller Shade Motor - Integration in HA and Review
Since many people frequently ask how to motorize roller blinds most effectively and often mention Zemismart motors, I would like to share my opinion on these motors and explain the setup for HomeAssistant.
I have the ZM16-TYZB-EU motor from Zemismart. It is suitable for roller blinds with an inner diameter of 17-28mm and can be controlled via RF and ZigBee. Zemismart has already released a Matter version for larger diameters, and they plan to release a Matter model for the 17-28mm version in the near future.
My version does not have a battery. Zemismart also offers versions with a battery, but I find those to be practical only with a solar panel, as charging blinds throughout the house would be very tedious. I had the opportunity to run USB cables to the motors.
The motors cost around 50€ each and are compatible for retrofitting most indoor roller blinds.
What is in the box:
The motor was well-packaged and comes with some accessories.
Attached to the motor itself are the ZigBee controller and an additional cable for RF reception. These can be hidden quite well behind the roller blinds, but integrating them into the casing of the motor would have been a more elegant solution.
There are various adapters for different inner diameters of the roller blinds.
Two brackets are included, but most times the brackets from the original roller blinds should also fit.
A 5V 1A power supply is included. Although the motor states that 2A is required, the 1A power supply is sufficient, and there is no performance improvement with a stronger power supply.
Unfortunatly, only a 1m long Micro-USB cable is included. This is far too short if there are no power outlets at the top of the window; I had to buy three additional long cables.
Installation:
Simply take the roller blind off the wall, remove the original chain mechanism, and insert the motor into the tube.
All functions can also be accessed without a remote control. However, I would definitely recommend buying one remote control for every 9 roller blinds. It is much easier to set the limits and activate the pairing mode this way, and you also have a backup control since the roller blind cannot be controlled directly on the motor itself.
Set the limits
With remote control
Pair motor to remote
  • Choose a channel on the remote by using the “+” and “-” buttons (C stands for all channels, this is only for control)
  • Press the motor’s “set button” once. The set button is under a hole on the motor and needs to be pressed with a sharp long object. The motor beeps shortly after pressing it.
  • Press “Move up” on the remote once within 5 sec after the previous step
Set Up Limit
  • Choose the channel of the shade you want to control
  • Move the Shade to the upper position with the “Move up”, “Inch up” and “Stop” buttons.
  • Press the “set button” on the remote once, the screen shows “1”.
  • Press “Move up” within the next 3 seconds from the previous step.
Set Down Limit
  • Same like upper limit, but press “Move down” instead of “Move up” in the last step
ZigBee only (without remote control)
If you don’t have a remote control, the limits can also be set via a ZigBee command. For this, you need Zigbee2MQTT and must run a short script. How this works is well described here: Configuring the Start and Stop Positions for a Zigbee Blinds Motor Without a Remote.
Put a motor in reverse
With remote control
  • Press the “set button” on the remote 4 times, the screen shows “4”.
Connect the Motor to ZigBee2MQTT (see next step). There you have the option to invert the control of the motor. Under “Settings (specific)” you can find this option.
Connect to HomeAssistant (ZigBee2MQTT)
With remote control
  • Choose the channel of the shade you want to connect via ZigBee
  • Press the “set button” on the remote 6 times, the screen shows “6”.
  • Press “Stop” within the next 5 seconds from the previous step. The motor beeps shortly.
  • Now permit the join in ZigBee2MQTT and the cover should be detected.
  • Power on the motor
  • Press the “Set Button” on the motor 3 times in 5 seconds. The set button is under a hole on the motor and needs to be pressed with a sharp long object.
  • The motor beeps shortly after pressing it.
Performance:
  • The top and bottom limits work very reliably and accurately.
  • The roller blinds are pulled without any issues; the motors have enough power even for slightly heavier blinds.
  • The roller blinds are not whisper-quiet, especially when several blinds are running simultaneously, but for me they are quiet enough. They are quieter than a SwitchBot Curtain 3. However, the sound is somewhat uneven, as you can see in this demo video.
Ideas:
I used the roller blinds to automatically adjust the position of 3 blinds so that the sun never directly hits my monitors. How I did this is explained in this post: Advanced Automated Blind Control Based on the Sun’s Position.
Points to Note:
  • Zemismart is a Chinese company; the motors need to be imported and are only available on their official website and on Aliexpress.
  • Zemismart’s support was not easy to reach; I had to write to them multiple times before getting a response.
  • I received the motors for free for a review, but this did not influence my opinion in any way.
Conclusion:
I can recommend the motors from Zemismart. At 50€, they are a good deal since higher-end products cost much more and offer similar performance. The only issues are the very short cable, the import from China (which can be problematic for issues or returns), and the mediocre support. Whether you take the risks of importing for the significantly lower price is a decision each person has to make for themselves.
I hope this was useful :slight_smile:
I have 12 of these across the house, they are very reliable, only thing on my wish list would be, battery level in HA and to be able to set 3 positions for day night blinds.
Thanks MLTE
I bought two Zemismart ZM16EL-0.3/33 motors that I want to connect to the Tuya app.
The motors arrived with nice instructions covering several versions on to connect to remotes and also to the Tuya app, however it is not clear that the instructions refer to the ZM16EL-0.3/33, since I have been unable to pair the motors with the Tuya app.
Here is a summary:-
The instructions refer to connecting to a WiFi dongle or a Zigbee
Motor pair to remote is:- Press motor setting button once.
Then there instructions on how to connect to the Tuya app with Zigbee - Press the motor setting button three times, motor “DI” once.
Then there is how to use the USB WiFi dongle version – Press the settings key for 5 seconds.
Then there is another pairing instruction Press the “setting button” on the motor once, the motor enters the pairing state.
Finally there is an instruction on how to reset the motor which may be most relevant to the Zemismart ZM16EL-0.3/33.
Press x 3 quickly Pair mode with Tuya app
Press x 5 quickly Pair Factory reset
I have seen elsewhere that pairing is only possible on 2.4GHz, so I have my Android phone temporarily pause the 5GHz setting on the router.
I have tried for days to get the ZM16EL to connect to the Tuya app without success.
I have contacted the seller for help, but nothing is forthcoming.
When I press the settings button x 3 quickly, there is a beep and the button flashes 3 times over a 5 second period, then stops.
I have tried adding device in the Tuya app by entering the various blind options in small home appliances
Any thoughts on what I am missing to pair the blind motors with the Tuya App?
Did you get the motor only version, or with remote? And have you got WiFI or Zigbee connectivity version?
I recently got a Zigbee one as a test for fitting throughout my house (No remote as thinking to purely use HA), but all the user knowledge and anecdotal instructions suggest pairing and setting limits with the remote before trying to pair with HA.
I’m going to pick up a remote, in the meantime, I need to design/adjust the adapters as they don’t fit B&Q 25mm tubes with large seams.
Excellent review and helpful instructions. About to order the ZM25TQ to fit my 2.5m wide roller blind, for integrating into Home Assistant, so this was a useful post for me. I’ll be using ZHA rather than ZigBee2MQTT, but Blakadder list says it is compatible with ZHA as well.
I have a couple of these blinds ZM25EL version. These are connected via ZHA. After setting the limits via the RF remote then they work well. However they only seem to work when setting a percentage open or closed.
Using the simple open or close doesn’t work. It is not the end of the world as I can set percentages in automations and the like, but it would be nice to get it fully working. Does anyone else have this issue?
Stephen
So this blind motor arrived today, and the first thing I noticed on having a quick check is that the power cable is only 93cm long! Maybe in China they have plug sockets half way up a wall, but here in the UK I’m gonna need at least double that length to reach the socket. Seems like a stupid decision by Zemismart - surely would have been better to have a longer cable which the end user could cut down if they needed to?
So I guess I’ll have to either extend the wires, or run an extension up the wall :roll_eyes:
Wasn’t that made quite clear in the initial review, or are you talking about a different cable?
It’s a different cable as I have a different blind motor. If it was a micro-USB cable I could just swap out with a longer one. I was expecting the cable to be connected to a plug and could just extend it, but it’s bare wires. I’m not sure why, since the less powerful version of this (this one is rated for 30w, the other ones is 22w) comes with a plug attached.
Should be able to use a couple of in line Wago connectors and some wire, and stick a plug in the end. But I still maintain it’s a stupid length of cable.
Well, I’ve got it paired to the remote, and it connected to Home Assistant directly via ZHA, but it’s not showing any entities in Home Assistant, which isn’t really useful.
I’ve tried adding it via the remote and via ZigBee only, with the same results
Ok, looking around, I found a thread on this specific model. I had checked the ZM25 on the compatability list but it looks like it’s an older model with a different Tuya chip that allows a quirk so it would run with ZHA.
Unfortunately the quirk doesn’t work with the newer model, it would appear, and it doesn’t seem there’s been a quirk made for the newer version, at least not that I could find.
I’m not actually sure if this would even work with Zigbee2MQTT anyway, and I really don’t want to switch from ZHA, since I’ve got a bunch of ZigBee devices linked, including every power socket in the house, and I don’t want to have to go around and re-pair everything with ZigBee2MQTT.
EDIT: Just ordered an SMLIGHT SLZB-06M and I’ll use it to run Zigbee2MQTT simultaneously with ZHA, and I’ll just add the blind to that for the moment. Then when I add other blinds, I can add them to it as well. And I can move my existing ZigBee network over a bit at a time, if I can be bothered!
EDIT 2: Got the SMLIGHT SLZB-06M, installed MQTT Mosquito and Zigbee2MQTT, set the SLZB as a coordinator, didn’t use the config SMLIGHT provide on their instruction page for port settings when connecting over ethernet, as it doesn’t work, used this instead:
port: tcp://slzb-06m.local:6638
baudrate: 115200
adapter: ember
disable_led: false
I also added the following to the /homeassistant/zigbee2mqtt/configuration.yaml
serial:
baudrate: 115200
adapter: ember
disable_led: false
transmit_power: 20
Added the blind. Works perfectly, exposes all entities.
Now I just need to add the motor to the blind and see if it can actually drive a 2.5m blind.
I have just taken delivery of a ZM16 with built in battery, purchased on Amazon but sent from China. 12 days for delivery, 6 of those were in the UK! The remote control and Zigbee2mqtt set up was straight forward, although the middle stopping point isn’t visible in HA and only works with the remote from the bottom stop point. I purchased the optional solar panel, but as it has only just been installed I don’t know if it will keep the battery charged.
The only issue I encountered was the 25mm adaptor was slightly smaller than the internal diameter of the Dunelm blind tube, but a little bit of squashing of the tube at the correct point solved it.
Update, the middle stop point is available in HA. I now have 3 set up in HA. I have recently had a couple of connection drop offs.
Hi everyone,
Total newbie here on HA! Looking to integrate this motor later into HA. There are 3 protocol versions. Which one would you recommend as the easiest one to integrate to HA? Ideally running a cloudless, local HA version. Thinking maybe the Matter one?
Appreciate your insights! Thanks!
easiest? either of the wifi version- but the matter version might not yet be as stable with all features (I don’t know - try a google search)…
Cloudless? well that definitely rules out the Tuya WiFI - possible to be fully local but by no means a newbie solution
As for the Zigbee you will need Zigbee coordinator adding - if you already have one, Zigbee is easy to add and set up and will be fully local.
So if you don’t have ZigBee, and want Cloudless, you’re left with Matter.
If you do have Zigbee, it’s your preference of integration.
Can anyone confirm that the ZM25EL can have custom positions set in home assistant (e.g 60%) in addition to fully open and fully closed? Looking at purchasing these but want to make sure i can do this before buying!
Quick update here, for anyone searching for an answer:
Finally got round to installing this motor in my 2.5m blind today (I know, it’s been a while, life got in the way, as it does), and it works flawlessly.
Got it exposed in Home Assistant, and then to voice assistants, and I can set the percentage open or closed with voice commands.
I wasn’t actually convinced the motor would have enough power to drive the blind, as it’s heavy, but was pleasantly surprised.
It’s not whisper quiet, but it’s not annoyingly loud, and I don’t mind it.
Thanks for the update!
Are you able to set the percentage opening within HA (ZHA) as well? And any idea if the solar panel works with the ZM25EL model?
How is ZM25TQ’s going with you? I have installed 4, here’s the summary:
ZHA:
  • 3 firmly connected to HA via ZHA
  • 1 at some point was connected after multiple pairing attempts. After a power off it stop transmitting. I removed from HA and I am in trouble again to pair it.
RF:
  • 4 connected to remote control via RF
  • 1 works differently from the other 3. When pressing up/down button once, the motor bounces a bit and stops. Only If I press long up/down, the motor goes up/down.
Any similarities with your case?
M.
I have a bunch of these on standby for when my IKEAs die. One is already in place. using Z2M They are blindingly easy to set up. Included them, use movement commands to get it where you want for either open or close, use the Z2M function to set that spot, then move it to the other position, set it. No need for the remote at all. They work great and are reliable, are about 25% faster than the Fyurturs. Noise level… about the same just a different pitch. a Motor Fault more or less just means you haven’t set the Open/Close limits. A weakness I do see… it seems to only go to 10% positions. Not that this matters all that much I don’t need single digit accuracy for blinds. To make these fit the IKEA tube I got the 17-27mm kit. used the largest wheels and put about 4 layers of electrical tape on one side. that wedged the nib of the other side into a track slot inside the tube.
I have mine exposed to Assist, and thus to HAVPE, with Gemini, which means I can verbally tell Jarvis to set the blinds to whatever percentage I want.
I’ve also got the blind motor integrated into my Unfolded Circle remote controls, via HA, if I want to use those instead, and that allows for 1% increments via a slider.
