I just bought the tuya zigbee hub. And connect the dongle to it.
Then what you have to do is. Press the button on the motor for 3 sec. It wil go to pairing mode. Then press blinds up on tuya app.the motor wil respond with turning up and down, Then it’s paired with the motor and the dongle.
After that you have to setup the down and up time in the tuya app.
Linking to like topic
It’s working now with Zigbee2mqtt.
https://www.zigbee2mqtt.io/devices/ZM-AM02_cover.html#zemismart-zm-am02_cover
Does each set of blinds really need a separate dongle?
Yes. Each blinds need there own dongle
Does anyone here know if the Zemismart zigbee to RF bridge is able to control NON Zemismart (Tuya) blind motors? I have some generic RF motors that work on the same standard 433MHz frequency. Brand is Raex. I’d like to be able to pair this dongle to my existing motors.
My existing zigbee network is running through zigbee2mqtt so ideally I don’t want to have to buy the Zemismart Zigbee bridge.
Hello, does anyone know how “mode” parameter work? There are 2 conditions “morning” and “night”. But I can not really find what is the diffenence. Help page does not explain much about this.
lets the motor work a bit quiter
Hi, have you managed to make it work with zigbee2mqtt? I mean did you pair blinds with the dongle using zigbee2mqtt? I tried to press the pair button 3 times and “OPEN” in the add-on as well as press the pair button for 3s and “OPEN” or press the pair button once and “OPEN” in the add-on without any success. ;(
yeah i use them with Z2mqtt. got them paired
i used the tuya hub for the height and low.
because i couldn’t do that with z2mqtt. or im doing it wrong.
after that i paired the dongle with z2mqtt. and all working great for almost 6 months
In the devices Z2M “Exposes” after you put he motor in paring mode and, select “up”. You’ll see the light on the motor blink fast. Viola, pared!
