Zemismart Zigbee Light Switch (Z811) - Does it work with ZHA?
I am keen on getting some smart switches that have a physical button rather than a touch sensitive switch (for family approval factor). I am in Australia and looking around there does not seem to be many options. I did come across this switch from Zemismart which looks like it should suit well:
It has 1/2/3 switch options which is great and will keep a consistent light switch throughout the home. I reached out to their support and enquired if they knew if it would work with ZHA, to which they replied that it would not. That is disappointing, especially considering Zigbee is meant to be an open standard.
My question, are they wrong? Has anyone tried these devices and can confirm if they work with ZHA? Thankyou!
Hello @DM-AU. For your information I just bought and received the 3 gang ZigBee option and it didn’t work in my home assistant environment using conbee 2 with deconz (it was never discovered)
Perhaps it might worth trying with sonoff zbdongle-p coordinator with ZigBee2Mqtt as it looks like having more compatibility with some tuya devices.
Thanks for the follow up. I also bought 1 to test. It connected straight up to ZHA on HA Yellow, the issue though is when triggering the switches from HA it toggles all 3 switches. I have raised an issue here:
Hopefully it can be resolved as its a really nice switch.
