Need to preface this with I am fairly new to HA and Z2M.
I have purchased a couple Zemismart ZMR4 wireless switches and can’t seem to get them to work. Z2M showing these as compatible but under a different model identifier: Zemismart ZMR4 control via MQTT | Zigbee2MQTT
The model of my switches is: _TZ3000_et7afzxz and not ‘_TZ3000_11pg3ima’ as defined in the Herdsman Converters.
I’ve just received my ZMR4’s and I believe the latest Z2M has fixed the issue. Events are coming through nicely for single, double click and hold features. Would be great if there was a blueprint to manage the device though as opposed to having to do my own automations from scratch
EDIT:
Nevermind, This is probably a better way to go rather than using a blueprint and quite straightforward to accomplish:
I spent a few hours struggling to get automations to work with a single click using the ZMR4, but by default, this switch only offers triggers based on state changes.
Then I had a moment of enlightenment, and a long-lost neuron in my brain reminded me to check all the events in the Developer Tools.
In Listen to events, I entered * to listen to all events.
When I clicked the button, the following event was registered:
