Based on the blueprint shared here: Zooz ZEN72
Just changes the Model from Zen72 to Zen72 800 LR
Thanks @IOT_Ninja
blueprint:
description: Automations helper for the Zooz ZEN72 Dimmer Switch using the
Zwave JS integration.
domain: automation
input:
zooz_zen72:
description: The ZEN72 Switch to interact with.
selector:
device:
integration: zwave_js
manufacturer: Zooz
model: ZEN72 800LR
dimmer_up_1x:
name: Top Paddle 1x
description: "Action to run on dimmer upper paddle single tap.
Default: Turn on dimmer switch load to last/custom/full/max brightness."
default: []
selector:
action: {}
dimmer_up_2x:
name: Top Paddle 2x
description: "Action to run on dimmer upper paddle double tap.
Default: Turn on dimmer switch to full/max/custom brightness."
default: []
selector:
action: {}
dimmer_up_3x:
name: Top Paddle 3x
description: "Action to run on dimmer upper paddle triple tap.
Default: Enter inclusion/pairing mode."
default: []
selector:
action: {}
dimmer_up_4x:
name: Top Paddle 4x
description: Action to run on dimmer upper paddle quadruple tap.
default: []
selector:
action: {}
dimmer_up_5x:
name: Top Paddle 5x
description: Action to run on dimmer upper paddle quintuple tap.
default: []
selector:
action: {}
dimmer_up_hold:
name: Top Paddle Hold
description: "Action to run on dimmer upper paddle press-and-hold.
Default: Increase dimmer brightness level."
default: []
selector:
action: {}
dimmer_up_release:
name: Top Paddle Release
description: Action to run on dimmer upper paddle release.
default: []
selector:
action: {}
dimmer_down_1x:
name: Lower Paddle 1x
description: "Action to run on dimmer lower paddle single tap.
Default: Turn off dimmer switch load."
default: []
selector:
action: {}
dimmer_down_2x:
name: Lower Paddle 2x
description: Action to run on dimmer lower paddle double tap.
default: []
selector:
action: {}
dimmer_down_3x:
name: Lower Paddle 3x
description: "Action to run on dimmer lower paddle triple tap.
Default: Enter exclusion/un-pairing mode."
default: []
selector:
action: {}
dimmer_down_4x:
name: Lower Paddle 4x
description: Action to run on dimmer lower paddle quadruple tap.
default: []
selector:
action: {}
dimmer_down_5x:
name: Lower Paddle 5x
description: Action to run on dimmer lower paddle quintuple tap.
default: []
selector:
action: {}
dimmer_down_hold:
name: Bottom Paddle Hold
description: "Action to run on dimmer lower paddle press-and-hold.
Default: Decrease dimmer brightness level."
default: []
selector:
action: {}
dimmer_down_release:
name: Bottom Paddle Release
default: []
selector:
action: {}
mode: single
max_exceeded: silent
- platform: event
event_type: zwave_js_value_notification
event_data:
command_class_name: Central Scene
device_id: !input zooz_zen72
- variables:
scene_id: "{{ trigger.event.data.label }}"
attribute_id: "{{ trigger.event.data.value }}"
- choose:
- conditions: "{{ scene_id == 'Scene 001' }}"
sequence:
- choose:
- conditions: "{{ attribute_id == 'KeyPressed' }}"
sequence: !input dimmer_up_1x
- conditions: "{{ attribute_id == 'KeyPressed2x' }}"
sequence: !input dimmer_up_2x
#- conditions: "{{ attribute_id == 'KeyPressed3x' }}"
#sequence: !input dimmer_up_3x
- conditions: "{{ attribute_id == 'KeyPressed4x' }}"
sequence: !input dimmer_up_4x
- conditions: "{{ attribute_id == 'KeyPressed5x' }}"
sequence: !input dimmer_up_5x
- conditions: "{{ attribute_id == 'KeyHeldDown' }}"
sequence: !input dimmer_up_hold
- conditions: "{{ attribute_id == 'KeyReleased' }}"
sequence: !input dimmer_up_release
- conditions: "{{ scene_id == 'Scene 002' }}"
sequence:
- choose:
sequence: !input dimmer_down_1x
sequence: !input dimmer_down_2x
#sequence: !input dimmer_down_3x
sequence: !input dimmer_down_4x
sequence: !input dimmer_down_5x
sequence: !input dimmer_down_hold
sequence: !input dimmer_down_release
