I think I found the error in the logs:
[homeassistant.components.recorder.util] Error executing query: (sqlite3.IntegrityError) UNIQUE constraint failed: statistics_meta.statistic_id
[SQL: UPDATE statistics_meta SET statistic_id=? WHERE statistics_meta.statistic_id = ? AND statistics_meta.source = ?]
[parameters: ('sensor.zen_thermostat_battery', 'sensor.zen_within_zen_01_battery', 'recorder')]
(Background on this error at: https://sqlalche.me/e/20/gkpj)
File "/usr/local/lib/python3.11/site-packages/sqlalchemy/engine/base.py", line 1968, in _exec_single_context
self.dialect.do_execute(
File "/usr/local/lib/python3.11/site-packages/sqlalchemy/engine/default.py", line 920, in do_execute
cursor.execute(statement, parameters)
sqlite3.IntegrityError: UNIQUE constraint failed: statistics_meta.statistic_id
File "/usr/src/homeassistant/homeassistant/components/recorder/util.py", line 130, in session_scope
yield session
File "/usr/src/homeassistant/homeassistant/components/recorder/statistics.py", line 680, in update_statistics_metadata
statistics_meta_manager.update_statistic_id(
File "/usr/src/homeassistant/homeassistant/components/recorder/table_managers/statistics_meta.py", line 316, in update_statistic_id
).update({StatisticsMeta.statistic_id: new_statistic_id})
File "/usr/local/lib/python3.11/site-packages/sqlalchemy/orm/query.py", line 3275, in update
self.session.execute(
File "/usr/local/lib/python3.11/site-packages/sqlalchemy/orm/session.py", line 2232, in execute
return self._execute_internal(
File "/usr/local/lib/python3.11/site-packages/sqlalchemy/orm/session.py", line 2127, in _execute_internal
result: Result[Any] = compile_state_cls.orm_execute_statement(
File "/usr/local/lib/python3.11/site-packages/sqlalchemy/orm/bulk_persistence.py", line 1619, in orm_execute_statement
return super().orm_execute_statement(
File "/usr/local/lib/python3.11/site-packages/sqlalchemy/orm/context.py", line 293, in orm_execute_statement
result = conn.execute(
File "/usr/local/lib/python3.11/site-packages/sqlalchemy/engine/base.py", line 1413, in execute
return meth(
File "/usr/local/lib/python3.11/site-packages/sqlalchemy/sql/elements.py", line 483, in _execute_on_connection
return connection._execute_clauseelement(
File "/usr/local/lib/python3.11/site-packages/sqlalchemy/engine/base.py", line 1637, in _execute_clauseelement
ret = self._execute_context(
File "/usr/local/lib/python3.11/site-packages/sqlalchemy/engine/base.py", line 1846, in _execute_context
return self._exec_single_context(
File "/usr/local/lib/python3.11/site-packages/sqlalchemy/engine/base.py", line 1987, in _exec_single_context
self._handle_dbapi_exception(
File "/usr/local/lib/python3.11/site-packages/sqlalchemy/engine/base.py", line 2344, in _handle_dbapi_exception
raise sqlalchemy_exception.with_traceback(exc_info[2]) from e
sqlalchemy.exc.IntegrityError: (sqlite3.IntegrityError) UNIQUE constraint failed: statistics_meta.statistic_id
2023-07-25 13:32:26.887 WARNING (Recorder) [homeassistant.components.recorder.statistics] Blocked attempt to insert duplicated statistic rows, please report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+recorder%22
yield session
return meth(
