I have a Pi4 running HA with everything on the latest versions
ZWaveJS - Driver 8.2.1 and Server 1.10.1
ZWaveJS to MQTT - 0.24.1
I have two configured Zen30 double switches. The relay switch (fan control) works on both switches but the dimmer light only works on one switch through ZWaveJS. If I use the ZWaveJS to MQTT control panel, the other dimmer works as well. Unfortunately this means I can’t control the one dimmer through the entity or any of the lovelace cards. It shows up, just doesn’t do anything. Any thoughts or things I should try?
