ZEN32 / ZEN35 Scene & LED Control - LTek
LED state tracking and scene control for the Zooz ZEN32 and ZEN35 scene
controllers over Z-Wave JS. Each button’s LED can mirror the state of any entity
(light, cover, lock, climate, sensor, etc.) while the button presses run your
own scenes/actions.
Substantial changes based on ZEN32-control-track.yaml by rwalker777
(original v2026.9.5); see the Credits section. This is a standalone
project, not a GitHub fork.
Install
Click the button above, or in Home Assistant go to Settings → Automations &
Scenes → Blueprints → Import Blueprint and paste:
https://raw.githubusercontent.com/LTek/zen32-zen35-control-ltek/main/zen32-zen35-control-ltek.yaml
This installs the blueprint under blueprints/automation/LTek/, so your
automations reference it as:
use_blueprint:
path: LTek/zen32-zen35-control-ltek.yaml
The import dialog shows the install path in an editable field, so you can
adjust it there if you ever want a different folder.
Example automation: examples/living-room-zen35.yaml
Features
- Per-button LED state tracking. Point a button at an entity; its LED color,
behavior and brightness reflect that entity’s on / off / unavailable state. - Global Defaults. One top-level section sets color, behavior and brightness
for on / off / unavailable states across all buttons. Any button that sets
its own value for an item overrides the matching default — otherwise it inherits
from Global Defaults. - Actions per button. Pressed once, held, released, and 2x–5x multi-tap,
each with its own action sequence. Includes the big relay button and a 3-way
switch (momentary, 800-series or 700-series firmware 10.40+). - Brightness on the device scale. LED brightness is chosen on the device’s own
1–10 scale (3 = Low, 6 = Medium, 10 = Bright). New-scale firmware (ZEN35 1.40+,
ZEN32 800LR 3.30+) is auto-detected; older firmware is remapped to its 3 levels
automatically. Detection can be manually overridden. - Conditional Override. Supply your own triggers and condition — any time,
entity, sun, numeric or template logic Home Assistant supports — then set
override behavior, color and brightness. Values are per button, so each LED
can react differently (or not at all) to the same condition. Replaces the old
fixed Night Time feature. - Relay / dimmer options. Smart-bulb mode and load/LED reporting (parameters
19 & 20), plus optional “turn off untracked LEDs.” The big button’s LED can be
driven by this blueprint or left to the device firmware.
How it works
The automation listens for Z-Wave scene notifications (button presses → Actions)
and for state changes on the tracked entities (→ LED updates). On each tracked
state change it writes three Z-Wave config parameters for that button —
behavior, color, and brightness — with a short delay between writes. A
startup/reload refresh re-syncs every LED to current entity state.
Each button’s settings live in two panels: Actions (what the presses do) and
LED Settings (the entity to track and how the LED looks).
Resolution order
Each of the three LED values — behavior, color, brightness — is resolved
independently, highest priority first:
| Priority | Source |
| 1 | Conditional Override value, while the override condition is true |
| 2 | Per-button value in that button’s LED Settings panel |
| 3 | Global Defaults |
An override field set to No Change falls through to the normal per-state
value, so you can dim every LED at night while each keeps its own colors.
Two inputs define when:
- Override Triggers — when to re-check (e.g. a time trigger at 22:00 and
another at 07:00). These only wake the automation. - Override Condition — whether the override is active (e.g. a time condition
for after 22:00). This is checked on every LED write, so the LEDs are also
correct after a restart, when no trigger fired.
Both are usually the same idea expressed twice. That is deliberate: a trigger is
an edge and a condition is a level, and the LEDs need the level to come up
correctly at startup.
Then set the values — globally in the same panel, or per button in that button’s
LED Settings panel. A button whose override values are all No Change ignores
the override entirely and keeps tracking normally.
# Dim every LED to 2 between sunset and sunrise, keeping each button's colors.
override_triggers:
- trigger: sun
event: sunset
- trigger: sun
event: sunrise
override_condition:
- condition: sun
after: sunset
before: sunrise
global_ovr_brightness: '2'
after: sunset + before: sunrise is Home Assistant’s canonical “when dark”
test — it holds from sunset until midnight and from midnight until sunrise. For a
fixed clock schedule, swap in trigger: time / at: and condition: time /
after: / before:. Inside the polar circles, use a sun-elevation template
(state_attr('sun.sun','elevation') < -6) instead.
Leave the Override Condition empty and the override runs all the time. An
empty condition list is vacuously true in Home Assistant. That is harmless
while the override values are all No Change, but once you set one — a
brightness, say — it applies 24/7 until you add the condition.
The big button (relay / dimmer)
The big button drives a real load — a relay on the ZEN32, a dimmer on the
ZEN35 — so its LED can come from either of two places. LED Control Mode picks
which:
| Mode | LED follows | Color / brightness | Night override | Z-Wave traffic |
| LED uses Blueprint setting (default) | your Entity to Track | yes | yes | a write per change |
| LED uses Buttons Firmware State | the attached load, in firmware | no — on/off only | no | none |
The two are mutually exclusive. In firmware mode the Entity to Track and every LED
value on that button — including the override ones — are ignored, and
Firmware LED State chooses whether the LED is on when the load is on or when
it’s off.
Blueprint mode is the default because it makes the big button behave like the four
scene buttons. Firmware mode is still the better pick if the big button only
switches its own load and you want the LED instant and silent on the mesh.
Setup
- Select your ZEN32 / ZEN35 device.
- (Optional) Set Global Defaults for the common look, then only customize the
buttons that differ. - For each button, open LED Settings, pick the entity to track and, if
desired, override color / behavior / brightness (leave as Global Default
to inherit). - Open Actions and add the presses you want to use.
- Configure the Conditional Override and relay options if needed.
Note: per-button color/behavior/brightness default to Global Default.
When upgrading an existing automation to this version, any option left at
default will follow Global Defaults; explicitly chosen values are preserved.
Upgrading from a version with Night Time
Night Time settings are not migrated — the old inputs no longer exist, so
their values are dropped silently. Reconfigure as follows:
| Old Night Time input | Replacement |
schedule_start / schedule_stop |
Two Override Triggers (time, at each) plus an Override Condition (time, after/before) |
night_entity |
One Override Trigger (state, on that entity) plus an Override Condition (state, that entity = on) |
invert_night_entity |
Invert the condition itself (not → state is off) |
night_led_brightness (Low/Medium/Bright) |
Override Brightness on the 1–10 scale (3 / 6 / 10) — globally, or per button |
night_led_color |
Override Color — globally, or per button |
Behavior set to On during daytime |
Behavior Always On + Override Behavior Always Off |
Two improvements come with the move: override brightness is now set per button
rather than one value flattening every LED, and it is scaled for the detected
firmware (the old night path accepted only the three names, so a numeric value
silently became “no change”).
Changelog
Current version: v2026.10.03.2. See CHANGELOG.md
for the full detailed history.
- 2026.10.03.2 — LED Control Mode on the big button: blueprint-driven
(new default) or firmware-driven. “Relay” wording is now “relay / dimmer,”
since the ZEN35’s big button is a dimmer. - 2026.10.03.1 — Night Time replaced by Conditional Override (user-supplied
triggers + condition, per-button override values). Button panels split into
Actions and LED Settings. Requires HA 2024.10+. Breaking: night
settings are not migrated. - 2026.10.02.2 — UI usability changes (layout, icons, labels).
- 2026.10.02.1 — Added Global Defaults; button number icons + cleaned-up
labels; “Multipress” renamed to “Scene Actions.” - 2026.10.01.2 — 1–10 brightness scale with automatic legacy remapping.
- From original (v2026.9.5) — Brightness values always validated before writing.
Credits
Based on the ZEN32 and ZEN35 Scene and State blueprint by
rwalker777 (original
v2026.9.5), which remains the upstream source. This project is an independently
maintained rework — not a GitHub fork — and tracks its own version history in
CHANGELOG.md. Two bug fixes in v2026.10.03.2 were identified by
cross-referencing the angelo-labs
fork of the same upstream.
