Trying to get the ios component setup on 0.54. I keep getting failed to setup dependencies and it seems to always be zeroconf. I tried a fresh install of 0.54 in venv, and the same error persists.
Downgrading to 0.52.1 is producing the same error with zeroconf.
Tried setting base_url to the machine IP, as well as the hostname for the hass instance.
ERROR:homeassistant.setup:Error during setup of component zeroconf
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/setup.py", line 194, in _async_setup_component
component.setup, hass, processed_config)
File "/usr/lib/python3.4/asyncio/futures.py", line 388, in __iter__
yield self # This tells Task to wait for completion.
File "/usr/lib/python3.4/asyncio/tasks.py", line 286, in _wakeup
value = future.result()
File "/usr/lib/python3.4/asyncio/futures.py", line 277, in result
raise self._exception
File "/usr/lib/python3.4/concurrent/futures/thread.py", line 54, in run
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/zeroconf.py", line 54, in setup
zeroconf.register_service(info)
File "/srv/homeassistant/lib/python3.4/site-packages/zeroconf.py", line 1754, in register_service
self.check_service(info, allow_name_change)
File "/srv/homeassistant/lib/python3.4/site-packages/zeroconf.py", line 1870, in check_service
raise NonUniqueNameException
zeroconf.NonUniqueNameException
Trying to install zeroconf manually produces no errors.
(homeassistant) homeassistant@Home-HASS:/ pip install zeroconf
Requirement already satisfied: zeroconf in /srv/homeassistant/lib/python3.4/site-packages
Requirement already satisfied: netifaces!=0.10.5 in /srv/homeassistant/lib/python3.4/site-packages (from zeroconf)
Requirement already satisfied: six in /srv/homeassistant/lib/python3.4/site-packages (from zeroconf)
Requirement already satisfied: enum-compat in /srv/homeassistant/lib/python3.4/site-packages (from zeroconf)
Can anyone point me in the right direction, its been a battle for a couple of days and everything I find doesn’t seem to help?
Relevant configs
Configuration.yaml
homeassistant: !include homeassistant.yaml
http: !include http.yaml
group: !include groups.yaml
script: !include scripts.yaml
mqtt: !include mqtt.yaml
zwave: !include zwave.yaml
switch: !include_dir_list switches/
media_player: !include_dir_list media_players/
frontend:
config:
updater:
discovery:
zeroconf:
conversation:
history:
logbook:
sun:
tts:
- platform: google
http.yaml
api_password: <Redacted>
ip_ban_enabled: true
base_url: hass.<Redacted>.com:8123
login_attempts_threshold: 5
