Zero Feed-in Control for PV Systems – Blueprint for Hoymiles + OpenDTU
I’ve made a blueprint to implement zero feed-in (zero injection) control for photovoltaic systems with 1, 2 or more inverters (must be identical).
I’m currently using it with Hoymiles micro-inverters and OpenDTU. It should work with other inverters if it provides the same kind of entities.
My goal was to dynamically limit PV production based on real-time grid import/export to avoid feeding excess energy into the grid (especially useful in regions with legal or contractual injection limits).
Direct URL to blueprint here
Credits
Based on work by AndreBott83 and the Selbstbau-PV project.
testing this blueprint, many thanks.
Could you add to the “Inverter Status” also the switch entities ? My inverter has a switch entitiy and so is now chooseable, i edit the yaml and it works, but its not the fine way :slight_smile:
Thanks, Ronny
I’ve updated the blueprint, you can reimport it.
Let me know if it solve your issue.
Thank you
Hi Makai,
works :slight_smile: Thanks.
Ronny
