Hello, running on a raspberry pi 3 and found recently that mDNS has been causing a large amount of traffic on my network, causing entities to go offline (mainly wemo, but harmony and a dlink camera too).
I moved all my google home device to a separate network, and then started to disable all I could in HA. I removed default_config, and added in the items I needed, ensuring not to include ssdp and zeroconf.
I turned off discovery in Wemo and turned off homekit.
The traffic is much much better, but with Wireshark I still see my pi broadcasting and responding to mDNS items, so something is still running.
Checking the Developer tool -> Info page I see that zeroconf is still loaded. I then checked the logs and sure enough it is still seen loading up. Turned on “debug” logs and see right off the bat that zeroconf is in the list:
2020-04-14 23:26:43 DEBUG (MainThread) [homeassistant.bootstrap] Setting up {'python_script', 'ios', 'config', 'sensor', 'script', 'emulated_hue', 'amcrest', 'myq', 'webhook', 'frontend', 'switch', 'harmony', 'zha', 'map', 'rachio', 'zeroconf', 'envisalink', 'binary_sensor', 'api', 'scene', 'device_automation', 'plex', 'nest', 'http', 'zone', 'zwave', 'sun', 'updater', 'group', 'onboarding', 'history', 'shell_command', 'system_health', 'neato', 'ffmpeg', 'websocket_api', 'lovelace', 'device_tracker', 'ecobee', 'wemo'}
Any ideas how to not get it to load? or what component is causing it to be added to the list?
Thank you!
