Hi everybody,
I was not able to figure this out despite multiple attempts, perhaps you can help me solve this problem? When I (re)start Home Assistant, I get this
I ran grep default_config home-assistant.log
and grep zeroconf home-assistant.log
with these results
2020-02-22 16:29:53 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of default_config. Setup failed for dependencies: zeroconf
2020-02-22 16:29:53 ERROR (MainThread) [homeassistant.setup] Setup failed for default_config: Could not set up all dependencies.
2020-02-22 16:29:51 ERROR (MainThread) [homeassistant.setup] Error during setup of component zeroconf
File "/usr/src/homeassistant/homeassistant/components/zeroconf/__init__.py", line 42, in setup
zeroconf = Zeroconf()
File "/usr/local/lib/python3.7/site-packages/zeroconf/__init__.py", line 2134, in __init__
File "/usr/local/lib/python3.7/site-packages/zeroconf/__init__.py", line 2062, in create_sockets
File "/usr/local/lib/python3.7/site-packages/zeroconf/__init__.py", line 2009, in add_multicast_member
This is my current version; I am running Home Assistant in a docker container
I don’t quite understand why dependencies would be missing; shouldn’t everything be right there in the docker container? I have had this issue before several updates, so this is not tied to 0.105.5
When I re-create my docker container, I run the commands below before starting the updated version from a docker-compose
file.
docker stop hass
docker rm hass
docker pull homeassistant/home-assistant:latest
home-assistant:
container_name: hass
image: homeassistant/home-assistant:latest
volumes:
environment:
- TZ=Europe/Berlin
restart: always
network_mode: host
What can I do to fix this? Everything seems to work without any issues, but I’d still like to fix this error in case they mess things up in the future. Thank you for your ideas
