First time trying to install Home Assistant via the official docs: Manual installation on a Raspberry Pi
Near the end of the install I get to the point where I I run
(homeassistant) homeassistant@raspi:/srv/homeassistant $ pip3 install homeassistant
and after it was done with that, I’m supposed to run it for the first time via
(homeassistant) homeassistant@raspi:/srv/homeassistant $ hass
This takes a minute or two when it’s stuck on Starting Zeroconf broadcast
, then I throws the Exception and is stuck in a loading state.
2020-01-28 23:25:58 INFO (SyncWorker_2) [homeassistant.components.zeroconf] Starting Zeroconf broadcast
Exception in thread zeroconf-ServiceBrowser__hap._tcp.local.:
Traceback
2020-01-28 23:25:56 INFO (MainThread) [homeassistant.setup] Setting up tts
2020-01-28 23:25:57 INFO (MainThread) [homeassistant.setup] Setup of domain tts took 0.0 seconds.
2020-01-28 23:25:57 INFO (SyncWorker_19) [homeassistant.loader] Loaded homekit_controller from homeassistant.components.homekit_controller
2020-01-28 23:25:58 INFO (MainThread) [homeassistant.bootstrap] Home Assistant initialized in 6.94s
2020-01-28 23:25:58 INFO (MainThread) [homeassistant.core] Starting Home Assistant
2020-01-28 23:25:58 INFO (MainThread) [homeassistant.core] Timer:starting
File "/usr/lib/python3.7/threading.py", line 917, in _bootstrap_inner
self.run()
File "/srv/homeassistant/lib/python3.7/site-packages/zeroconf/__init__.py", line 1483, in run
handler(self.zc)
File "/srv/homeassistant/lib/python3.7/site-packages/zeroconf/__init__.py", line 1423, in <lambda>
zeroconf=zeroconf, service_type=self.type, name=name, state_change=state_change
File "/srv/homeassistant/lib/python3.7/site-packages/zeroconf/__init__.py", line 1301, in fire
h(**kwargs)
File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/components/zeroconf/__init__.py", line 88, in service_update
service_info = zeroconf.get_service_info(service_type, name)
File "/srv/homeassistant/lib/python3.7/site-packages/zeroconf/__init__.py", line 2176, in get_service_info
info = ServiceInfo(type_, name)
File "/srv/homeassistant/lib/python3.7/site-packages/zeroconf/__init__.py", line 1530, in __init__
if not type_.endswith(service_type_name(name, allow_underscores=True)):
File "/srv/homeassistant/lib/python3.7/site-packages/zeroconf/__init__.py", line 262, in service_type_name
raise BadTypeInNameException("Type '%s' must end with '._tcp.local.' or '._udp.local.'" % type_)
zeroconf.BadTypeInNameException: Type 'hap-059F40.local.' must end with '._tcp.local.' or '._udp.local.'
Additional information
- I have a Raspberry Pi 4 (4GB) with a good 3A power supply, running from a class 10 SD card.
- Raspbian Buster Lite is installed
- Some noteworthy packages I’ve install over the past few days:
- Apache
- MariaDB
- PHP 7.3
- Homebridge
- Domoticz (not my cup of tea, hence this install)
I have also tried reinstall zeroconf, which was mentioned in a different ticket here somewhere.
pip install zeroconf==0.24.0
I have also tried upgrading homeassistant after a full reboot because someone said it might load different dependencies then, no luck.
pip3 install --upgrade homeassistant
I have no idea what to do or try next?
