Hello everyone: I am trying to finish configuring home assistant in docker but on linux.
The error is with zeroconf and the integration of zeroconf with sonoff
They can think of how I can fix these errors. I read a lot and did not find the solution. Thank you
Detalles de registro (ERROR)
Logger: homeassistant.setup
Source: components/zeroconf/__init__.py:177
First occurred: 23:19:27 (1 occurrences)
Last logged: 23:19:27
Error during setup of component zeroconf
File "/usr/src/homeassistant/homeassistant/setup.py", line 191, in _async_setup_component
result = await task
File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run
File "/usr/src/homeassistant/homeassistant/components/zeroconf/__init__.py", line 177, in setup
info = ServiceInfo(
File "/usr/local/lib/python3.8/site-packages/zeroconf/__init__.py", line 1756, in __init__
self._set_properties(properties)
File "/usr/local/lib/python3.8/site-packages/zeroconf/__init__.py", line 1824, in _set_properties
result = b''.join((result, int2byte(len(item)), item))
struct.error: ubyte format requires 0 <= number <= 255
Source: setup.py:118
First occurred: 23:19:27 (2 occurrences)
Setup failed for sonoff: Could not set up all dependencies.
Setup failed for ios: Could not set up all dependencies.
