I recently purchased a cheap ZH07 particulate sensor and I want to integrate this with my esphome setup. Unfortunately, there is no already made sensor component for this and making the custom sensor was unsuccessful but I managed to get a working arduino code. No idea how I could put the arduino code to make it work in esphome or what to change in the code to make this compatible with esphome. Any ideas?
I just cannot make it work with the custom sensor, the arduino code that I have is a bit more complex than usual. I belive I mainly fail to make the my_custom_sensor.h file with a working code that esphome can read.
This is the code that I am trying to use:
PM2.5 Demo
pm25-demo.ino
Demonstrates operation of PM2.5 Particulate Matter Sensor
ESP32 Serial Port (RX = 16, TX = 17)
Derived from howtoelectronics.com - https://how2electronics.com/interfacing-pms5003-air-quality-sensor-arduino/
DroneBot Workshop 2022
https://dronebotworkshop.com
// Serial Port connections for PM2.5 Sensor
#define RXD2 16 // To sensor TXD
#define TXD2 17 // To sensor RXD
void setup() {
// our debugging output
Serial.begin(115200);
// Set up UART connection
Serial1.begin(9600, SERIAL_8N1, RXD2, TXD2);
struct pms5003data {
uint16_t framelen;
uint16_t pm10_standard, pm25_standard, pm100_standard;
uint16_t pm10_env, pm25_env, pm100_env;
uint16_t particles_03um, particles_05um, particles_10um, particles_25um, particles_50um, particles_100um;
uint16_t unused;
uint16_t checksum;
struct pms5003data data;
void loop() {
if (readPMSdata(&Serial1)) {
// reading data was successful!
Serial.println();
Serial.println("---------------------------------------");
Serial.println("Concentration Units (standard)");
Serial.print("PM 1.0: "); Serial.print(data.pm10_standard);
Serial.print("\t\tPM 2.5: "); Serial.print(data.pm25_standard);
Serial.print("\t\tPM 10: "); Serial.println(data.pm100_standard);
Serial.println("Concentration Units (environmental)");
Serial.print("PM 1.0: "); Serial.print(data.pm10_env);
Serial.print("\t\tPM 2.5: "); Serial.print(data.pm25_env);
Serial.print("\t\tPM 10: "); Serial.println(data.pm100_env);
Serial.print("Particles > 0.3um / 0.1L air:"); Serial.println(data.particles_03um);
Serial.print("Particles > 0.5um / 0.1L air:"); Serial.println(data.particles_05um);
Serial.print("Particles > 1.0um / 0.1L air:"); Serial.println(data.particles_10um);
Serial.print("Particles > 2.5um / 0.1L air:"); Serial.println(data.particles_25um);
Serial.print("Particles > 5.0um / 0.1L air:"); Serial.println(data.particles_50um);
Serial.print("Particles > 10.0 um / 0.1L air:"); Serial.println(data.particles_100um);
boolean readPMSdata(Stream *s) {
if (! s->available()) {
return false;
// Read a byte at a time until we get to the special '0x42' start-byte
if (s->peek() != 0x42) {
s->read();
return false;
// Now read all 32 bytes
if (s->available() < 32) {
return false;
uint8_t buffer[32];
uint16_t sum = 0;
s->readBytes(buffer, 32);
// get checksum ready
for (uint8_t i = 0; i < 30; i++) {
sum += buffer[i];
/* debugging
for (uint8_t i=2; i<32; i++) {
Serial.print("0x"); Serial.print(buffer[i], HEX); Serial.print(", ");
Serial.println();
// The data comes in endian'd, this solves it so it works on all platforms
uint16_t buffer_u16[15];
for (uint8_t i = 0; i < 15; i++) {
buffer_u16[i] = buffer[2 + i * 2 + 1];
buffer_u16[i] += (buffer[2 + i * 2] << 8);
// put it into a nice struct :)
memcpy((void *)&data, (void *)buffer_u16, 30);
if (sum != data.checksum) {
Serial.println("Checksum failure");
return false;
// success!
return true;
I tried to make it more similar to the example from the Custom Sensor Component-ESPHome link. Any idea how I can get this code into a esphome version?
