ZHA - 1-Button (TS004F)
Hi everyone!
I just created my first blueprint for those very cheap single buttons identified as TS004F using the ZHA integration. Manufacturer is TZ3000_ja5osu5g and it is sold as eWeLink ZB-K1.
It supports:
  • Single press
  • Double press
  • Long press
It works by listening specifically to the press_type command sent by the device and filters out the extra noise from other events like toggle or remote_button_short_press.
Let me know what you think, and feel free to suggest improvements.
blueprint:
  name: ZHA - 1-Button (TS004F)
  description: |
    Handle single, double and long presses from 1-button devices identified as TS004F button using ZHA.
  domain: automation
  input:
    remote:
      name: TS004F 1-Button Device
      description: Select the TS004F 1-button
      selector:
        device:
          integration: zha
          model: TS004F
    single_press_action:
      description: Action to run on single press
      default: []
      selector:
        action: {}
    double_press_action:
      description: Action to run on double press
      default: []
      selector:
        action: {}
    long_press_action:
      description: Action to run on long press
      default: []
      selector:
        action: {}
mode: single
  - platform: event
    event_type: zha_event
    event_data:
      device_id: !input remote
      command: press_type
  - variables:
      press_type: "{{ trigger.event.data.args[0] | int }}"
  - choose:
      - conditions:
          - condition: template
            value_template: "{{ press_type == 0 }}"
        sequence: !input single_press_action
      - conditions:
            value_template: "{{ press_type == 1 }}"
        sequence: !input double_press_action
      - conditions:
            value_template: "{{ press_type == 2 }}"
        sequence: !input long_press_action
Very nice! I tried to use the long press function to change the brightness, but that long_press event is just too short to make sense for changing brightness significantly (changed just about 10% or so)
So I got carried away a bit and did the following:
short_press: switch on or off (toggle)
double_press: increase brightness in 4 steps
long_press: decrease brightness in 4 steps
for the increase and decrease I used a scripts and a helper, but see yourself:
Automation:
alias: Bedroom_Switch_Door_3-functions
description: β€œβ€
use_blueprint:
path: lehenandmartin/ZHA-1-Button-TS004F.yaml
input:
remote: 395220573487ff9bf11a5e4ba912f593
- target:
entity_id: input_number.brightness_level_step
action: input_number.increment
data: {}
- action: script.set_brightness_from_helper
data: {}
long_press_action:
- target:
action: input_number.decrement
data: {}
data: {}
- target:
device_id: a53398b04d9c9218636bcf19da48d179
action: light.toggle
data: {}
Script:
alias: Set brightness from helper
description: β€œβ€
mode: single
sequence:
  • variables:
    brightness_map:
    β€œ0”: 1
    β€œ1”: 15
    β€œ2”: 50
    β€œ3”: 100
  • data:
    brightness_pct: >
    {% set level = states(β€˜input_number.brightness_level_step’) | int %} {%
    set level_str = level | string %} {{ brightness_map.get(level_str, 15)
    action: light.turn_on
Helper:
Min: 0
Max: 3
Then I got carried away even more and added 3 more automations for brightness presets for different daytimes or sunrise…
Automation 1:
alias: "Morgens ab 10:00 Uhr Helligkeit auf 50 % setzen "
description: β€œβ€
triggers:
  • trigger: time
    at: β€œ10:00:00”
    conditions:
    actions:
  • target:
    value: 2
    action: input_number.set_value
    mode: single
Automation 2:
alias: Morgens u. Abends Helligkeit auf 15 % setzen
description: β€œβ€
triggers:
  • trigger: sun
    event: sunrise
    offset: "00:15:00 "
  • trigger: sun
    event: sunset
    conditions:
    actions:
  • target:
    value: 1
    mode: single
Automation 3:
alias: Nachts Helligkeit auf 1 Prozent setzen
description: β€œβ€
triggers:
  • trigger: sun
    event: sunset
    offset: β€œ00:30:00”
    conditions:
    actions:
  • target:
    value: 0
    mode: single
Hello.
Got an error about trigger.event.data.args[0]
So, there is my solution for, i think, updated buttons software:
alias: Button.Oleg.Actions
description: ""
triggers:
  - event_type: zha_event
    event_data:
      device_id: d5ed6718404ca774de00e797f94519b8
    trigger: event
actions:
  - choose:
      - conditions:
            value_template: "{{ trigger.event.data.command == 'toggle' }}"
        sequence:
          - type: toggle
            device_id: 358ad44333b1c3751f28e18765b134b9
            entity_id: 27879349ecb7faa255335fff6e16591c
            domain: light
      - conditions:
            value_template: "{{ trigger.event.data.command == 'off' }}"
        sequence:
          - type: toggle
            device_id: 0a6131734cc333357d04938d92dd5d19
            entity_id: 691640c88b997506f21b5795a339b0f5
            domain: light
      - conditions:
            value_template: "{{ trigger.event.data.command == 'on' }}"
        sequence:
          - type: toggle
            device_id: bf4072eb1849cdfd745cc412f52ddedb
            entity_id: f179c7b7b6c1241e7dfb8107e78515be
            domain: light
mode: single
Here is a new blueprint for the updated version
blueprint:
  description: |
  domain: automation
  input:
    remote:
      selector:
        device:
          integration: zha
          model: TS004F
      default: []
      selector:
        action: {}
      default: []
      selector:
        action: {}
    long_press_action:
      default: []
      selector:
        action: {}
mode: single
  - platform: event
    event_data:
#      command: press_type
  - variables:
      press_type: "{{ trigger.event.data.command }}"
  - choose:
      - conditions:
            value_template: "{{ press_type == 'toggle' }}"
      - conditions:
            value_template: "{{ press_type == 'on' }}"
      - conditions:
            value_template: "{{ press_type == 'off' }}"
Thanks @Peter_Junker but this update still produced an error for me. Using hints from other posts I updated the press_type variable from:
  - variables:
to:
  - variables:
      press_type: "{{ trigger.event.data.command | string}}"
Simple automations I’ve tested are successful with this change.
