ZHA Add devices is now missing
Latest updates in Hassio has removed ‘add devices’ page and pairing log from ZHA in configuration manager. I’ve attempted to use call service:zha.permit however I have not been successful in any pairing attempts and without the log its difficult to see if I am making any progress at all! I have set MQTT tab listen to ‘#’ (not sure what pairing topic is) but cant see any activity from the device.
The device in question is a MCCGQ01LM xiaomi contact sensor (window / door). I have pressed and held the pairing button and waited for 3 long flashes then continued to press the pairing button every 2-3 seconds or so for several minuites but no luck. I have tried long press for 3 flashes then pressed again and held to see lots of quick flashes followed by a single long flash. ive tried every combination of button press and waits I can think of for 2 hours now but have no idea what to do now!
is ZHA now always llistening for new devices and doesnt need the add devices page? how can one confirm the pairing process?
I have the same problem. somehow deconz isn’t working anymore now i like to test zha but how. without pairing new devices
ive just discovered the ZHA add devices page is not under integrations but at the bottom the the configuration page you will see “zigbee home automation”. Perhaps there is similar with deconz?
