ZHA and ikea devices
Hi folks. having some issues. I want to switch to using my ikea devices via ZHA. I have a TI CC2531 USB stick which is detected in ZHA.
When i first installed I manage to get an ikea socket connected. the e1743 controller however I simply couldnt get it to connect. so I tried a remove integration, reboot, re-install. Again the controller is detected without issue. But now I can’t add anything, not even the socket I already installed once (factory reset to reinstall). There is zero info in the logs.
does anyone have a decent step by step guide to adding ikea devices (there more vids than you can shake a stick at for non ikea products)? Is this maybe an 2.4GHZ interference thing?
If this doesnt work I’ll take a look at other zigbee options but I wanted to tyrey and keep it simple and ZHA seemed to be the better option for that.
Any pointers appreciated.
I don’t know about ZHA, but if a CC2531 has problems pairing in Zigbee2mqtt, the usual solution is to stop zigbee2mqtt, remove the stick, plug it back in, start zigbee2mqtt and try pairing again. This might work for ZHA too.
Ikea devices are notorious for not wanting to pair to controllers running on any other channels besides 11, 15, 22 or 25. These channels are typically used for ZLL (Zigbee Light Link) and it’s where Ikea devices perform best. Also, they are notorious for not fully resetting. When I have to re-pair my Ikea devices, I typically reset them three times (6 on/off cycles for lights and 4 seconds holding reset for remotes) before ever attempting to pair them plus I move them right next to the controller. So, check which channel you have your controller set to and if it isn’t one of the 4 listed above, I’d try changing your Zigbee channel. It’s a MASSIVE PAIN IN THE A$$, but it might work.
The other piece of advice I have is that if you have a Hue hub, try adding them to that and then using the Hue integration to get them into HA. The reason being is that most Ikea devices are ZLL profile devices that downgrade to ZHA when attached to a ZHA controller. This will cause problems eventually (devices dropping, improper routing, etc). I’m not 100% sure, but I think the CC2531 handles both ZLL and ZHA equally, so you might be OK there.
