This may be a stupid question, but I am not very experienced with HA so I try my luck at this community.
I have connected all my Lidl color lights via the Conbee II stick and ZHA integration. On default there was always this temperature slider for every light:
I used this slider to set the correct light temperature, because the brightness of the Lidl lights is really bad when a color is chosen from the Color wheel. But now the slider is not present anymore, I can only use the color wheel?
What is the cause of this change? Is it an update of Home Assistant itself or from the ZHA intergration? What can I do to get it back?
I also have a Lidl Silvercrest LED bulb which shows up in Zigbee as a LivarnoLux Bulb TS0505A.
[Note several different devices are mapped to TS0505A - mine shows up as S0505A by _TZ3000_dbou1ap4]
About two releases ago, this was exposed as a colour bulb, but the white was generated from R+G+B so was pretty poor. There was a PR to change the Zigbee definition for the device to a simple LED bulb which turned it into a decently bright white LED bulb, but removed all colours.
What our devices really need is a Zigbee definition in the HASS integration that recognises the device as R+G+B+Cool+Warm - effectively 4 or 5 sets of LEDs to map to white colour temp OR colour.
The PR itself separates colour from colour temperature - which fits as these bulbs have both RGB and 2x white.
Iâm happy to report that my LivarnoLux Bulb TS0505A (S0505A by _TZ3000_dbou1ap4) also is controllable for RGB and colour temperature - fixed by David!
Hello, I just switched to Home Assistant yesterday and all works great except my Lidl RGBCW light, I cant change the color. How did you manage to get it to work?
All the details are linked above - fixed in HASS release 2022.08
Sadly, replying to two year old threads doesnât usually lead to insight.
Iâd instead recommend starting a new thread with the exact model / details of your bulb as Lidl / Aldi kit tens to change manufacturer / chipset / software regularly.
The Zigbee integration (likely ZHA) should get the manufacturer / model code from the firmware and apply any âquirksâ (special fixes for buggy non-standard behaviour). This is what changed back in 2022.08 and added back colour to my device.
