I am trying to use the rotation as a volume control, is there any way to increase the impact of each rotation? Increase or decrease the volume more for each rotation?
Thanks, awesome blueprint!!!
Here’s a light dimmer, should give you some ideas…
Hello Team,
I get follow error : : Error: UndefinedError: ‘dict object’ has no attribute ‘event’
The cube is available in HA with Sonoff Zigbee 3.0 USB Dongle Plus - Sonoff Zigbee 3.0 ZBdongle-P
any idea ?
I know it’s an awfully long time since this was developed, however, I still use it because it’s simple, works and doesn’t need an extra input_boolean to keep track of the faces.
I thought I’d make sure other people know of a few little extras I’ve had to put in over time to keep it working.
Since things have changed in the Zigbee/HA world, I’ve had to do the following:
All instances of “from_face” need to be replaced with “deactivated_face”.
The blueprint is (inexplicably) missing code for the 90 degree flip from face one to four and from four to one.
Original Code:
- conditions:
- '{{ flip_degrees == 90 and activated_face == 1 }}'
sequence:
- choose:
- conditions: '{{ from_face == 2 }}'
sequence: !input 'two_to_one'
- conditions: '{{ from_face == 3 }}'
sequence: !input 'three_to_one'
- conditions: '{{ from_face == 5 }}'
sequence: !input 'five_to_one'
- conditions: '{{ from_face == 6 }}'
sequence: !input 'six_to_one'
AND
- conditions:
- '{{ flip_degrees == 90 and activated_face == 4 }}'
sequence:
- choose:
sequence: !input 'two_to_four'
sequence: !input 'three_to_four'
sequence: !input 'five_to_four'
sequence: !input 'six_to_four'
New Code:
- conditions:
sequence:
- choose:
- conditions: '{{ deactivated_face == 2 }}'
- conditions: '{{ deactivated_face == 3 }}'
- conditions: '{{ deactivated_face == 4 }}'
sequence: !input 'four_to_one'
- conditions: '{{ deactivated_face == 5 }}'
- conditions: '{{ deactivated_face == 6 }}'
AND
- conditions:
sequence:
- choose:
- conditions: '{{ deactivated_face == 1 }}'
sequence: !input 'one_to_four'
I’ve spelled it out this way in case Brent decides to edit the available blueprint to the new version and people can see where the changes are.
Total New Code is:
blueprint:
name: Aqara Magic Cube
description: Control anything using Aqara Magic Cube.
domain: automation
input:
remote:
description: Select the Aqara Magic Cube device
selector:
device:
integration: zha
manufacturer: LUMI
multiple: false
flip_90:
name: Flip 90 degrees
description: 'Actions to run when cube flips 90 degrees.
This cancels all specific 90 degrees functions.
e.g From side 1 to side 2 will be the same as from side 6 to side 2'
default: false
selector:
boolean: {}
cube_flip_90:
name: Flip cube 90 degrees
description: Action to run when cube flips 90 degrees. This only works if 'Flip
90 degrees' is toggled
default: []
selector:
action: {}
flip_180:
name: Flip 180 degrees
description: 'Actions to run when cube flips 180 degrees.
This cancels all specific 180 degrees functions
e.g From side 1 to side 4 will be the same as from side 5 to side 2'
default: false
selector:
boolean: {}
cube_flip_180:
name: Flip cube 180 degrees
description: Action to run when cube flips 180 degrees. This only works if 'Flip
180 degrees' is toggled
default: []
selector:
action: {}
flip_any:
name: Flip to any side
description: 'Actions to run when cube flips to any side.
This cares about the end side, but cancels all specific flip functions.
but different than side 1 to side 5'
default: false
selector:
boolean: {}
cube_flip_1:
name: Flip cube to side 1
description: Action to run when cube flips to side 1. This only works if 'Flip
any' is toggled
default: []
selector:
action: {}
cube_flip_2:
name: Flip cube to side 2
description: Action to run when cube flips to side 2. This only works if 'Flip
any' is toggled
default: []
selector:
action: {}
cube_flip_3:
name: Flip cube to side 3
description: Action to run when cube flips to side 3. This only works if 'Flip
any' is toggled
default: []
selector:
action: {}
cube_flip_4:
name: Flip cube to side 4
description: Action to run when cube flips to side 4. This only works if 'Flip
any' is toggled
default: []
selector:
action: {}
cube_flip_5:
name: Flip cube to side 5
description: Action to run when cube flips to side 5. This only works if 'Flip
any' is toggled
default: []
selector:
action: {}
cube_flip_6:
name: Flip cube to side 6
description: Action to run when cube flips to side 6. This only works if 'Flip
any' is toggled
default: []
selector:
action: {}
slide_any_side:
name: Slide any side
description: 'Actions to run when cube slides on any side.
This cancels all specific ''slide'' functions
e.g Slide on side 1 will be the same as slide on side 2'
default: false
selector:
boolean: {}
cube_slide_any:
name: Slide cube on any side
description: Action to run when cube slides on any slide. This only works if
'Slide any side' is toggled
default: []
selector:
action: {}
knock_any_side:
name: Knock on any side
description: 'Actions to run when knocking cube regardless of the side.
This cancels all specific ''knock'' functions
e.g Knock on side 1 will be the same as knocking side 2'
default: false
selector:
boolean: {}
cube_knock_any:
name: Knock cube on any side
description: Action to run when knocking cube on any side. This only works if
'Knock on any side' is toggled
default: []
selector:
action: {}
one_to_two:
name: From side 1 to side 2
description: Action to run when cube goes from side 1 to side 2
default: []
selector:
action: {}
one_to_three:
name: From side 1 to side 3
description: Action to run when cube goes from side 1 to side 3
default: []
selector:
action: {}
one_to_four:
name: From side 1 to side 4
description: Action to run when cube goes from side 1 to side 4
default: []
selector:
action: {}
one_to_five:
name: From side 1 to side 5
description: Action to run when cube goes from side 1 to side 5
default: []
selector:
action: {}
one_to_six:
name: From side 1 to side 6
description: Action to run when cube goes from side 1 to side 6
default: []
selector:
action: {}
two_to_one:
name: From side 2 to side 1
description: Action to run when cube goes from side 2 to side 1
default: []
selector:
action: {}
two_to_three:
name: From side 2 to side 3
description: Action to run when cube goes from side 2 to side 3
default: []
selector:
action: {}
two_to_four:
name: From side 2 to side 4
description: Action to run when cube goes from side 2 to side 4
default: []
selector:
action: {}
two_to_five:
name: From side 2 to side 5
description: Action to run when cube goes from side 2 to side 5
default: []
selector:
action: {}
two_to_six:
name: From side 2 to side 6
description: Action to run when cube goes from side 2 to side 6
default: []
selector:
action: {}
three_to_one:
name: From side 3 to side 1
description: Action to run when cube goes from side 3 to side 1
default: []
selector:
action: {}
three_to_two:
name: From side 3 to side 2
description: Action to run when cube goes from side 3 to side 2
default: []
selector:
action: {}
three_to_four:
name: From side 3 to side 4
description: Action to run when cube goes from side 3 to side 4
default: []
selector:
action: {}
three_to_five:
name: From side 3 to side 5
description: Action to run when cube goes from side 3 to side 5
default: []
selector:
action: {}
three_to_six:
name: From side 3 to side 6
description: Action to run when cube goes from side 3 to side 6
default: []
selector:
action: {}
four_to_one:
name: From side 4 to side 1
description: Action to run when cube goes from side 4 to side 1
default: []
selector:
action: {}
four_to_two:
name: From side 4 to side 2
description: Action to run when cube goes from side 4 to side 2
default: []
selector:
action: {}
four_to_three:
name: From side 4 to side 3
description: Action to run when cube goes from side 4 to side 3
default: []
selector:
action: {}
four_to_five:
name: From side 4 to side 5
description: Action to run when cube goes from side 4 to side 5
default: []
selector:
action: {}
four_to_six:
name: From side 4 to side 6
description: Action to run when cube goes from side 4 to side 6
default: []
selector:
action: {}
five_to_one:
name: From side 5 to side 1
description: Action to run when cube goes from side 5 to side 1
default: []
selector:
action: {}
five_to_two:
name: From side 5 to side 2
description: Action to run when cube goes from side 5 to side 2
default: []
selector:
action: {}
five_to_three:
name: From side 5 to side 3
description: Action to run when cube goes from side 5 to side 3
default: []
selector:
action: {}
five_to_four:
name: From side 5 to side 4
description: Action to run when cube goes from side 5 to side 4
default: []
selector:
action: {}
five_to_six:
name: From side 5 to side 6
description: Action to run when cube goes from side 5 to side 6
default: []
selector:
action: {}
six_to_one:
name: From side 6 to side 1
description: Action to run when cube goes from side 6 to side 1
default: []
selector:
action: {}
six_to_two:
name: From side 6 to side 2
description: Action to run when cube goes from side 6 to side 2
default: []
selector:
action: {}
six_to_three:
name: From side 6 to side 3
description: Action to run when cube goes from side 6 to side 3
default: []
selector:
action: {}
six_to_four:
name: From side 6 to side 4
description: Action to run when cube goes from side 6 to side 4
default: []
selector:
action: {}
six_to_five:
name: From side 6 to side 5
description: Action to run when cube goes from side 6 to side 5
default: []
selector:
action: {}
one_to_one:
name: Knock - Side 1
description: Action to run when knocking on side 1
default: []
selector:
action: {}
two_to_two:
name: Knock - Side 2
description: Action to run when knocking on side 2
default: []
selector:
action: {}
three_to_three:
name: Knock - Side 3
description: Action to run when knocking on side 3
default: []
selector:
action: {}
four_to_four:
name: Knock - Side 4
description: Action to run when knocking on side 4
default: []
selector:
action: {}
five_to_five:
name: Knock - Side 5
description: Action to run when knocking on side 5
default: []
selector:
action: {}
six_to_six:
name: Knock - Side 6
description: Action to run when knocking on side 6
default: []
selector:
action: {}
slide_on_one:
name: Slide - Side 1 up
description: Action to run when slides with Side 1 up
default: []
selector:
action: {}
slide_on_two:
name: Slide - Side 2 up
description: Action to run when slides with Side 2 up
default: []
selector:
action: {}
slide_on_three:
name: Slide - Side 3 up
description: Action to run when slides with Side 3 up
default: []
selector:
action: {}
slide_on_four:
name: Slide - Side 4 up
description: Action to run when slides with Side 4 up
default: []
selector:
action: {}
slide_on_five:
name: Slide - Side 5 up
description: Action to run when slides with Side 5 up
default: []
selector:
action: {}
slide_on_six:
name: Slide - Side 6 up
description: Action to run when slides with Side 6 up
default: []
selector:
action: {}
cube_wake:
name: Wake up the cube
description: Action to run when cube wakes up
default: []
selector:
action: {}
cube_drop:
description: Action to run when cube drops
default: []
selector:
action: {}
cube_shake:
description: Action to run when you shake the cube
default: []
selector:
action: {}
rotate_right:
description: Action to run when cube rotates right
default: []
selector:
action: {}
rotate_left:
description: Action to run when cube rotates left
default: []
selector:
action: {}
source_url: https://community.home-assistant.io/t/zha-aqara-magic-cube-57-actions/297012
mode: restart
max_exceeded: silent
- platform: event
event_type: zha_event
event_data:
device_id: !input remote
- variables:
command: '{{ trigger.event.data.command }}'
value: '{{ trigger.event.data.args.value | default(0) }}'
flip_degrees: '{{ trigger.event.data.args.flip_degrees | default(0) }}'
flip_any: !input flip_any
flip_90: !input flip_90
flip_180: !input flip_180
slide_any_side: !input slide_any_side
knock_any_side: !input knock_any_side
flip90: 64
flip180: 128
slide: 256
knock: 512
shake: 0
drop: 3
activated_face: "\n{% if command == \"slide\" or command == \"knock\" %}\n\n {%
if trigger.event.data.args.activated_face == 1 %} 1\n\n {% elif trigger.event.data.args.activated_face
== 2 %} 5\n\n {% elif trigger.event.data.args.activated_face == 3 %} 6\n\n
\ {% elif trigger.event.data.args.activated_face == 4 %} 4\n\n {% elif trigger.event.data.args.activated_face
== 5 %} 2\n\n {% elif trigger.event.data.args.activated_face == 6 %} 3\n\n
\ {% endif %}\n\n{% elif command == 'flip' %}\n\n {{ trigger.event.data.args.activated_face
| int }}\n\n{% endif %}\n"
deactivated_face: "\n{% if command == \"flip\" and flip_degrees == 90 %}\n\n {{ ((value
- flip90 - (trigger.event.data.args.activated_face - 1)) / 8) + 1 | int }}\n\n{%
endif %}\n"
relative_degrees: "\n{% if command == \"rotate_right\" or command == \"rotate_left\"
%}\n\n {{ trigger.event.data.args.relative_degrees | float }}\n\n{% endif %}\n"
- choose:
- conditions:
- '{{ command == ''rotate_right'' }}'
sequence: !input rotate_right
- conditions:
- '{{ command == ''rotate_left'' }}'
sequence: !input rotate_left
- conditions:
- '{{ command == ''checkin'' }}'
sequence: !input cube_wake
- conditions:
- '{{ value == shake }}'
sequence: !input cube_shake
- conditions:
- '{{ value == drop }}'
sequence: !input cube_drop
- conditions:
- '{{ command == ''knock'' and knock_any_side }}'
sequence: !input cube_knock_any
- conditions:
- '{{ command == ''slide'' and slide_any_side }}'
sequence: !input cube_slide_any
- conditions:
- '{{ command == ''flip'' and flip_any }}'
sequence:
- choose:
- conditions: '{{ activated_face == 1 }}'
sequence: !input cube_flip_1
- conditions: '{{ activated_face == 2 }}'
sequence: !input cube_flip_2
- conditions: '{{ activated_face == 3 }}'
sequence: !input cube_flip_3
- conditions: '{{ activated_face == 4 }}'
sequence: !input cube_flip_4
- conditions: '{{ activated_face == 5 }}'
sequence: !input cube_flip_5
- conditions: '{{ activated_face == 6 }}'
sequence: !input cube_flip_6
- conditions:
- '{{ flip_degrees == 90 and flip_90 }}'
sequence: !input cube_flip_90
- conditions:
- '{{ flip_degrees == 180 and flip_180 }}'
sequence: !input cube_flip_180
- conditions:
sequence:
- choose:
sequence: !input two_to_one
sequence: !input three_to_one
sequence: !input four_to_one
sequence: !input five_to_one
sequence: !input six_to_one
- conditions:
- '{{ flip_degrees == 90 and activated_face == 2 }}'
sequence:
- choose:
sequence: !input one_to_two
sequence: !input three_to_two
sequence: !input four_to_two
sequence: !input six_to_two
- conditions:
- '{{ flip_degrees == 90 and activated_face == 3 }}'
sequence:
- choose:
sequence: !input one_to_three
sequence: !input two_to_three
sequence: !input four_to_three
sequence: !input five_to_three
- conditions:
sequence:
- choose:
sequence: !input one_to_four
sequence: !input two_to_four
sequence: !input three_to_four
sequence: !input five_to_four
sequence: !input six_to_four
- conditions:
- '{{ flip_degrees == 90 and activated_face == 5 }}'
sequence:
- choose:
sequence: !input one_to_five
sequence: !input three_to_five
sequence: !input four_to_five
sequence: !input six_to_five
- conditions:
- '{{ flip_degrees == 90 and activated_face == 6 }}'
sequence:
- choose:
sequence: !input one_to_six
sequence: !input two_to_six
sequence: !input four_to_six
sequence: !input five_to_six
- conditions:
- '{{ value == flip180 + activated_face - 1 }}'
sequence:
- choose:
sequence: !input five_to_two
sequence: !input six_to_three
sequence: !input two_to_five
sequence: !input three_to_six
- conditions:
- '{{ command == ''knock'' and not knock_any_side }}'
sequence:
- choose:
sequence: !input one_to_one
sequence: !input two_to_two
sequence: !input three_to_three
sequence: !input four_to_four
sequence: !input five_to_five
sequence: !input six_to_six
- conditions:
- '{{ value == slide + activated_face - 1 }}'
sequence:
- choose:
sequence: !input slide_on_one
sequence: !input slide_on_two
sequence: !input slide_on_three
sequence: !input slide_on_four
sequence: !input slide_on_five
sequence: !input slide_on_six
Hope this helps someone! ![]()
Lloyd.
Or you can use mine. I keep mine maintained. There will be a release next week for all 20 of mine or sooner with some of the updates from the latest HA release 2024.6.
The input section of blueprints are going to be labeled and collapsed to make things less confusing for users and simpler to use.
Is the Aqara Cube not worth buying if I only use zigbee2MQTT and not ZHA?
thanks
It works better in Z2M if you have the Pro version. ZHA doesn’t have quirks for the new version.
Blueprints are great, but I find this to be a bit overkill for my use-case.
All I want is to be able to detect whether the cube is flipped rightways or leftways, independent of from-face and to-face.
When I inspect the zha_event stream, I find that any flip (right. left, up or down) all gives 90 degrees. So is there any other easy way to determine the flip direction except for a ton of if-then-else based on face numbers?
Not without tracking the side you are on, the side you flipped to, and how the thing is oriented to you, IE what face is towards you. There is no sensor for that last one, so, again, no.
I suggest using rotation. You CAN detect of you are rotating CW or CCW, and you have a number of degrees it turned, so you can look if it turned a lot or a little, for instance.
See here…
Thank you. Even ChatGPT eventually gave up on my challenge (after a lot of haluzinations).
Another question: With every event coming from the Cube, there’s an argument called ‘value:’ with a number that varies a lot.
What does that number mean, an for what purpose can it be used?
I have no point of reference for that. Do you have an example?
I believe that is the code from the cube that the zigbee software uses to know the command sent.
You could map them out and key off them if you wanted to,but that’s what I use Zigbee to do.
That’ just “guess-work” as good as any. The same command i.e. “knock” repeatingly generates different values every time.
I never could get this going properly, it only seemed to dim and never brighten… might need to try it again and get some use out of this little cube!
so T1 cubes just no longer work for specific side automations like it used too.
Hello @ganonderp
Are you in scene mode or action mode.
They should work in action mode.
