Did anybody get the ~2 model working?
Not sure if that’s the right place to ask, but my b1acn01 on ZHA is really unreliable. It keeps going offline every single day after I reset and reconnect it. My other Zigbee devices which are farther and also battery powered (curtain thingies from Aqara too) are perfectly fine. Just this damned switch (I got 5 of them to see if it was an issue with only 1) is consistently unreliable.
Is there something obvious I’m not thinking of? Are there better alternatives people usually go to that I haven’t seen? (never had issues with my hue switch but I want something simpler with just 1 button)
Hello. I’m new to HA and I’m trying to add an Automation when I press my Aqara Wireless Mini Switch T1 once or twice, but when I use the Blueprint it does not find my device from the list, my device comes up as lumi.remote.b1acn02 in Device Info. Any tips on how to get this resolved?
You may have a currently incompatible version of the switch. Look at this issue reported on GitHub and if that is the same situation, make sure to report it there that it’s still not working. Of course, make sure to be on the latest version of Home Assistant.
https://github.com/home-assistant/core/issues/103265
Hmm, I would like to use it this way too.
Did you find a solution for this?
Thank you for the blueprint, got my switch working perfectly. One doubt only, is there a way to extract the battery level from the switch?
