Thanks! This worked perfectly for me.
I set a single click of the button to toggle my lights, did not set the double or hold⌠Sometimes I notice it turns the lights on/off very fast with the single click⌠Is there something Iâm doing wrong or something to add to the automation to avoid it firing off the switch toggle multiple times instead of just once?
I had already linked my button to home assistant but wasnât sure how to get it up and running.
Found your page from google, and had my new button up and working in a couple of minutes! Thank you very much!
Mine is listed as lumi.remote.b1acn01 and works well.
Under device info, it shows this as well.
Quirk: zhaquirks.xiaomi.aqara.sensor_switch_aq3.SwitchAQ3B
May want to see if yours is showing the same.
Hey, i added this blueprint, but i cant choose any of my switches! all of them aqara mini switch added via zigbee2mqtt. what is the problem?
Thank you so much for this Blueprint! Took my battery reporter and made it a functional smart switch.
dove trovo lâid del dispositivo?
Dove trovo il device_id?
Developer Tools > Events tab > Listen to Events > enter âzha_eventsâ > Start Listening
Immediately, after you start listening, single press the button, then double tap, then press and hold for like five seconds. You can repeat that a couple times if youâd like, but donât wait long or drastically increases the amount of data captured, which could be very busy.
Press Stop Listening. Review the events captured and locate the device_id for the single, double, hold, and release commands. They should all be the same device.
Hope this helps!
I am experiencing the same problem. Under devices it shows
lumi.remote.b1acn01
by unk_manufacturer
I tried listening to the zha_event and get nothing when I press the button.
I think I stopped the add process too soon. I removed it using zha.remove
service call from Developer tools and then re-added it. I had to keep pressing the reset button every 2-3 second during the setup to keep the button awake until it was successfully added (found that trick here ZHA can not remove device - #6 by mrakar)
Does anyone have a suggestion on how to configure âpress - longpressâ action? Iâd like to use the mini switch to:
- single press: toggle the lights on/off
- double press: (not configured yet)
- long press: increase light level by 2% every 100ms (slow fade on)
- press immediately followed by a long press: decrease light level by 2% every 100ms (slow fade off)
- release long press: stop fading
Alternatively, how do you use the mini switch to control dimmable lights? Thanks!
I have ZHA installed but getting this error when I try to save the automation Message malformed: Integration ââ not found
Any ideas?
My issue seemed to be because was trying to use a Shelly device as one of the actions, once I deleted that one it saved.
Now to see why that didnât work.
i have 3 lumi.remote.b1acn01. I config them via bluepink. Bluepink detected 3 button but its ok for first button. second button and thirth button can not config.
I created bluepink on button number 1 and it ran very well. But when creating bluepink for button number 2, they donât run. Press button button number 1, they run both automations
I just got my Aqara Wireless Mini Switch T1, and it is model lumi.remote.b1acn02
, not lumi.remote.b1acn01
. I tried editing the blueprint, replacing the model with lumi.remote.b1acn02
, but it does not work. It wonât register button clicks. Any advice?
I created this separate thread with more details: Issue with Aqara Wireless Mini Switch T1
Apparently these have a model # somewhere. Check out this thread to see if it applies to the one that you have.
wxkg11lm
Does anyone have an experience with using WXKG12LM model? It shows up as âsensor_switch.aq3â and is exposing only battery & switch in sensors. Would appreciate if anyone could guide on how to get single press, double press, and so on other entities available for this specific model of Aqara Wireless Mini Switch.
Have also tried following blue print but it doesnât help either.
blueprint:
name: ZHA - Aqara Wireless Mini Switch
description: Automate your Xiaomi Aqara Wireless Mini Switch using ZHA events.
domain: automation
input:
aqara_mini_switch:
name: Aqara Wireless Mini Switch
description: Aqara Wireless Mini Switch to use
selector:
device:
integration: zha
manufacturer: LUMI
model: lumi.sensor_switch.aq3
multiple: false
button_single_press:
description: Action to run on single press
default: []
selector:
action: {}
button_double_press:
description: Action to run on double press
default: []
selector:
action: {}
button_long_press:
description: Action to run when button is long pressed (held down)
default: []
selector:
action: {}
button_released:
description: Action to run when button is released after a long press
default: []
selector:
action: {}
button_shaken:
description: Action to run when shaken
default: []
selector:
action: {}
source_url: https://gist.github.com/wwohl/becda6f749423bc3f06b4fcdc0ad6556
mode: restart
max_exceeded: silent
- platform: event
event_type: zha_event
event_data:
device_id: !input aqara_mini_switch
- variables:
command: '{{ trigger.event.data.command }}'
- choose:
- conditions:
- '{{ command == ''single'' }}'
sequence: !input button_single_press
- conditions:
- '{{ command == ''double'' }}'
sequence: !input button_double_press
- conditions:
- '{{ command == ''hold'' }}'
sequence: !input button_long_press
- conditions:
- '{{ command == ''release'' }}'
sequence: !input button_released
- conditions:
- '{{ command == ''shake'' }}'
sequence: !input button_shaken
