Having trouble adding a new: Aqara Radiator Thermostat E1 / TRV to my Home-Assistant install. I’ve got a SkyConnect which is connected to an Aqara curtain motor and several other Zigbee devices without issue but something appears to go wrong when adding the E1 TRV. Log output as follows:
File "/usr/src/homeassistant/homeassistant/components/zha/core/cluster_handlers/__init__.py", line 353, in async_configure
await self.configure_reporting()
File "/usr/src/homeassistant/homeassistant/components/zha/core/cluster_handlers/__init__.py", line 277, in configure_reporting
self._configure_reporting_status(reports, res[0])
File "/usr/src/homeassistant/homeassistant/components/zha/core/cluster_handlers/__init__.py", line 328, in _configure_reporting_status
failed = [
File "/usr/src/homeassistant/homeassistant/components/zha/core/cluster_handlers/__init__.py", line 329, in <listcomp>
self.cluster.find_attribute(record.attrid).name
File "/usr/local/lib/python3.11/site-packages/zigpy/zcl/__init__.py", line 233, in find_attribute
return self.attributes[name_or_id]
KeyError: 900
Looking at the error output it looks like something unhandled / unexpected is being passed back when adding the device. My first port of call was to check the device firmware, but I can’t seem to read anything back over the Zigbee network so that limits the option there.
Attempts to interact with the device return the following;
File "/usr/local/lib/python3.11/site-packages/bellows/zigbee/application.py", line 870, in send_packet
raise zigpy.exceptions.DeliveryError(
zigpy.exceptions.DeliveryError: Failed to deliver message: <EmberStatus.DELIVERY_FAILED: 102>
Any thoughts or suggestions?
