ZHA changes the decice's working method, cannot fix
Hi All,
I have an issue with my legrand 752184 no neutral zigbee switches. If i use them with phoscon (Conbee 2), or without zigbee network, they are working fine. If I connect with ZHA (Skyconnect) the working method of the switch has been modified by itself.
There are two smd switches on the board, on and off. But when the switches are working fine, both of the switches are working like a toggle switch. If I connected with ZHA the switches are start working as the label says, on and off. I made 2 videos about the problem. I hope, somebody could help me.
Video1 works fine: https://youtube.com/shorts/ya5V9dJvFDE?feature=share
Video2 not works: https://youtube.com/shorts/FFYeRPZsS88?feature=share
In my mind, video2 is actually correct. You have a rocker switch where pressing the top of the switch turns the light off, and the bottom of the switch turns the light on. This mirrors the behaviour of a normal light switch.
In video1, it doesn’t seem to matter which part (top or bottom) of the switch you press, it just toggles the light.
You can probably fix this with a local quirk, or a simple automation, assuming the device presents two switch entities in the device properties.
The video1 is the wanted method. Withouth Zigbee network or with phoscon works like in video 1. And I’d like to achive this with ZHA. With automation won’t work fine, because the switch will control the lamp locally and after it i will run an automation. It works with latency, I tested it. I have 17 switches, so I’d like to solve this problem. I’m going to ZHA from phoscon and this problem stopped the project more than a month ago.
