Hi all,
I am trying to install ZHA at home assistant core (comunity package) on a synology ds216j. Note that these means that I don’t use docker (it is not supported by my NAS. I have plugged a conbee 2 usb which is correctly recongnized by the system.
Then I install the ZHA integration follwing the steps showed at https://www.home-assistant.io/integrations/zha/.
I am asked for the usb path: /dev/ttyACM0 << automatically detected
I am asked for the radio: deconz selected
Then I am asked for the serial path. At this point I am lost. By default it shows /dev/ttyACM0 which is correct but not accepted.
According to documentation it should be used a path similar to this one: /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2128859-if00
The problem is that /dev/serial does no exist on my system. According to instructions a list of available device paths can be found in Supervisor > System > Host System > dot menu > Hardware, however as I running HA core (the only option available for my device) the tab supervisor does not exist!
This is an extract of log (using /dev/ttyACM0):
2021-04-16 15:20:16 WARNING (MainThread) [zigpy_znp.zigbee.application] Failed to probe ZNP radio with config {‘path’: ‘/dev/ttyACM0’, ‘flow_control’: None, ‘baudrate’: 115200}
File “/volume1/@appstore/homeassistant/env/lib/python3.8/site-packages/serial/serialposix.py”, line 322, in open
self.fd = os.open(self.portstr, os.O_RDWR | os.O_NOCTTY | os.O_NONBLOCK)
PermissionError: [Errno 13] Permission denied: ‘/dev/ttyACM0’
File “/volume1/@appstore/homeassistant/env/lib/python3.8/site-packages/zigpy_znp/zigbee/application.py”, line 167, in probe
await znp.connect()
File “/volume1/@appstore/homeassistant/env/lib/python3.8/site-packages/zigpy_znp/api.py”, line 199, in connect
self._uart = await uart.connect(self._config[conf.CONF_DEVICE], self)
File “/volume1/@appstore/homeassistant/env/lib/python3.8/site-packages/zigpy_znp/uart.py”, line 153, in connect
transport, protocol = await serial_asyncio.create_serial_connection(
File “/volume1/@appstore/homeassistant/env/lib/python3.8/site-packages/serial_asyncio/init.py”, line 445, in create_serial_connection
serial_instance = serial.serial_for_url(*args, **kwargs)
File “/volume1/@appstore/homeassistant/env/lib/python3.8/site-packages/serial/init.py”, line 90, in serial_for_url
instance.open()
File “/volume1/@appstore/homeassistant/env/lib/python3.8/site-packages/serial/serialposix.py”, line 325, in open
raise SerialException(msg.errno, “could not open port {}: {}”.format(self._port, msg))
serial.serialutil.SerialException: [Errno 13] could not open port /dev/ttyACM0: [Errno 13] Permission denied: ‘/dev/ttyACM0’
How should I know which value use or how should I config ZHA?
