Hoping someone can help. So about 3 days ago i set up my Conbee 2 and everything was working fine (Settings > Devices > Add Integration > ZHA) and my first automation was a switch to turn on/off my PC power socket which also worked fine 3 days ago, this morning (day 4) pressed the button nothing happened, logged in to HA and in devices i found under Conbee 2 “Failed to set up” i checked the logs and i had an error ( Error setting up entry ConBee II for zha) and a warning (Couldn’t start deCONZ) tried to find something online to help but didn’t have much luck but what i did find was
first remove ZHA Intergration, delete .db file and then restart HA - This didn’t work
second plug Conbee stick into a PC and flash new firmware - this didn’t work
third combination of both didn’t work - but when i went to set up the Conbee stick all 3 times when i selected “Erase network and set up new” it would just error out and i would have to go with “Keep current network settings”
Tried installing deConz (add-on Store > deCONZ) this would install but not start, and would cause a 3rd error in ZHA.
Everything is updated i even tried restoring to the last knowen working retore but it still did nothing. Please can someone help? to me it sounds like it could be a faulty Conbee stick (i think)
here are the error files
1st one
Logger: homeassistant.config_entries
Source: components/zha/core/gateway.py:172
First occurred: 11:27:32 PM (1 occurrences)
Last logged: 11:27:32 PM
File "/usr/local/lib/python3.10/site-packages/zigpy_deconz/zigbee/application.py", line 137, in change_loop
await asyncio.sleep(CHANGE_NETWORK_WAIT)
File "/usr/local/lib/python3.10/asyncio/tasks.py", line 605, in sleep
return await future
asyncio.exceptions.CancelledError
File "/usr/local/lib/python3.10/asyncio/tasks.py", line 456, in wait_for
return fut.result()
File "/usr/local/lib/python3.10/site-packages/zigpy_deconz/zigbee/application.py", line 111, in start_network
await self._change_network_state(NetworkState.CONNECTED)
File "/usr/local/lib/python3.10/site-packages/zigpy_deconz/zigbee/application.py", line 140, in _change_network_state
await asyncio.wait_for(change_loop(), timeout=timeout)
File "/usr/local/lib/python3.10/asyncio/tasks.py", line 458, in wait_for
raise exceptions.TimeoutError() from exc
asyncio.exceptions.TimeoutError
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 365, in async_setup
result = await component.async_setup_entry(hass, self)
File "/usr/src/homeassistant/homeassistant/components/zha/__init__.py", line 112, in async_setup_entry
await zha_gateway.async_initialize()
File "/usr/src/homeassistant/homeassistant/components/zha/core/gateway.py", line 185, in async_initialize
raise exc
File "/usr/src/homeassistant/homeassistant/components/zha/core/gateway.py", line 172, in async_initialize
self.application_controller = await app_controller_cls.new(
File "/usr/local/lib/python3.10/site-packages/zigpy/application.py", line 144, in new
await app.startup(auto_form=auto_form)
File "/usr/local/lib/python3.10/site-packages/zigpy/application.py", line 125, in startup
await self.initialize(auto_form=auto_form)
File "/usr/local/lib/python3.10/site-packages/zigpy/application.py", line 107, in initialize
await self.start_network()
File "/usr/local/lib/python3.10/site-packages/zigpy_deconz/zigbee/application.py", line 113, in start_network
raise FormationFailure() from e
zigpy.exceptions.FormationFailure
2nd one
Logger: homeassistant.components.zha.core.gateway
Integration: Zigbee Home Automation (documentation, issues)
First occurred: 11:27:05 PM (3 occurrences)
Couldn't start deCONZ = dresden elektronik deCONZ protocol: ConBee I/II, RaspBee I/II coordinator (attempt 1 of 3)
Couldn't start deCONZ = dresden elektronik deCONZ protocol: ConBee I/II, RaspBee I/II coordinator (attempt 2 of 3)
Couldn't start deCONZ = dresden elektronik deCONZ protocol: ConBee I/II, RaspBee I/II coordinator (attempt 3 of 3)
return await future
return fut.result()
