Hey there, i’ve updatet my ha to 2024.2.4 and had struggle to get the ZHA working - restartet a few times and plugged the conbee 2 in and out - it startet working again after 20-30 minutes. But only for maybe 1-2 hours.
The next day i went to 2024.2.5 - and now i can not get it working any more - no matter what i do - restart - replug - nothing seems to work.
I’ve ordered ha skyconnect stick - hope this is working better.
Any tips on migrating without loosing any device?
But in meantime - someone has an idea?
(All the days before there was no problem - its a pi4 and conbee 2 - on usb 2 with extention cable.
Here are some debug logs - if anyone can see anything there:
2024-02-29 18:01:57.521 DEBUG (MainThread) [zigpy_deconz.uart] Connecting to /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2408482-if00
2024-02-29 18:01:57.521 DEBUG (MainThread) [zigpy.serial] Opening a serial connection to '/dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2408482-if00' (115200 baudrate)
2024-02-29 18:01:57.528 DEBUG (MainThread) [zigpy_deconz.uart] Connection made
2024-02-29 18:01:57.529 DEBUG (MainThread) [zigpy_deconz.uart] Connected to /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2408482-if00
2024-02-29 18:01:57.529 DEBUG (MainThread) [zigpy_deconz.api] Sending CommandId.read_parameter{'parameter_id': <NetworkParameter.protocol_version: 34>, 'parameter': b''} (seq=1)
2024-02-29 18:01:57.530 DEBUG (MainThread) [zigpy_deconz.uart] Send: 0a01000800010022
2024-02-29 18:01:59.331 DEBUG (MainThread) [zigpy_deconz.api] No response to 'CommandId.read_parameter' command with seq 1
2024-02-29 18:01:59.335 DEBUG (Thread-22) [aiosqlite] executing functools.partial(<function PersistingListener._set_isolation_level.<locals>.<lambda> at 0x7f84f6cb80>)
2024-02-29 18:01:59.336 DEBUG (Thread-22) [aiosqlite] operation functools.partial(<function PersistingListener._set_isolation_level.<locals>.<lambda> at 0x7f84f6cb80>) completed
2024-02-29 18:01:59.338 DEBUG (Thread-22) [aiosqlite] executing functools.partial(<built-in method execute of sqlite3.Connection object at 0x7fa07874c0>, 'PRAGMA wal_checkpoint;', [])
2024-02-29 18:01:59.339 DEBUG (Thread-22) [aiosqlite] operation functools.partial(<built-in method execute of sqlite3.Connection object at 0x7fa07874c0>, 'PRAGMA wal_checkpoint;', []) completed
2024-02-29 18:01:59.341 DEBUG (MainThread) [zigpy_deconz.api] Serial '/dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2408482-if00' connection lost unexpectedly: None
2024-02-29 18:01:59.341 DEBUG (Thread-22) [aiosqlite] executing functools.partial(<function PersistingListener._set_isolation_level.<locals>.<lambda> at 0x7f826647c0>)
2024-02-29 18:01:59.342 DEBUG (Thread-22) [aiosqlite] operation functools.partial(<function PersistingListener._set_isolation_level.<locals>.<lambda> at 0x7f826647c0>) completed
2024-02-29 18:01:59.346 DEBUG (Thread-22) [aiosqlite] executing functools.partial(<built-in method close of sqlite3.Connection object at 0x7fa07874c0>)
2024-02-29 18:01:59.349 DEBUG (Thread-22) [aiosqlite] operation functools.partial(<built-in method close of sqlite3.Connection object at 0x7fa07874c0>) completed
2024-02-29 18:01:59.351 DEBUG (MainThread) [homeassistant.components.zha] Failed to set up ZHA
File "/usr/local/lib/python3.12/site-packages/zigpy_deconz/api.py", line 590, in _command
return await fut
asyncio.exceptions.CancelledError
File "/usr/src/homeassistant/homeassistant/components/zha/__init__.py", line 163, in async_setup_entry
zha_gateway = await ZHAGateway.async_from_config(
File "/usr/src/homeassistant/homeassistant/components/zha/core/gateway.py", line 196, in async_from_config
await instance.async_initialize()
File "/usr/src/homeassistant/homeassistant/components/zha/core/gateway.py", line 214, in async_initialize
await app.startup(auto_form=True)
File "/usr/local/lib/python3.12/site-packages/zigpy/application.py", line 225, in startup
await self.connect()
File "/usr/local/lib/python3.12/site-packages/zigpy_deconz/zigbee/application.py", line 97, in connect
await api.connect()
File "/usr/local/lib/python3.12/site-packages/zigpy_deconz/api.py", line 466, in connect
await self.version()
File "/usr/local/lib/python3.12/site-packages/zigpy_deconz/api.py", line 814, in version
self._protocol_version = await self.read_parameter(
File "/usr/local/lib/python3.12/site-packages/zigpy_deconz/api.py", line 833, in read_parameter
rsp = await self.send_command(
File "/usr/local/lib/python3.12/site-packages/zigpy_deconz/api.py", line 508, in send_command
return await self._command(cmd, **kwargs)
File "/usr/local/lib/python3.12/site-packages/zigpy_deconz/api.py", line 589, in _command
async with asyncio_timeout(COMMAND_TIMEOUT):
File "/usr/local/lib/python3.12/asyncio/timeouts.py", line 115, in __aexit__
raise TimeoutError from exc_val
TimeoutError
