today i did the latest 2023.10 core update. The update went trough without any problems, but now my Deconz Conbee II Zigbee stick completely stopped working and all my entities are offline…
I already tried to restore to the backup before the core update and a complete restore of the VM - nothing works.
I’m running HAOS in a proxmox VM
I hope someone can help me with it…
Here is the log:
Logger: homeassistant.config_entries
Source: config_entries.py:399
First occurred: 13:06:15 (1 occurrences)
Last logged: 13:06:15
Error setting up entry ConBee II for zha
File "/usr/local/lib/python3.11/site-packages/zigpy_deconz/api.py", line 313, in _command
return await fut
asyncio.exceptions.CancelledError
File "/usr/local/lib/python3.11/site-packages/zigpy/application.py", line 197, in startup
await self.connect()
File "/usr/local/lib/python3.11/site-packages/zigpy_deconz/zigbee/application.py", line 88, in connect
self.version = await api.version()
File "/usr/local/lib/python3.11/site-packages/zigpy_deconz/api.py", line 465, in version
(self._proto_ver,) = await self.read_parameter(
File "/usr/local/lib/python3.11/site-packages/zigpy_deconz/api.py", line 430, in read_parameter
r = await self._command(Command.read_parameter, 1 + len(data), param, data)
File "/usr/local/lib/python3.11/site-packages/zigpy_deconz/api.py", line 312, in _command
async with asyncio_timeout(COMMAND_TIMEOUT):
File "/usr/local/lib/python3.11/asyncio/timeouts.py", line 111, in __aexit__
raise TimeoutError from exc_val
TimeoutError
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 399, in async_setup
result = await component.async_setup_entry(hass, self)
File "/usr/src/homeassistant/homeassistant/components/zha/__init__.py", line 172, in async_setup_entry
await zha_gateway.async_initialize()
File "/usr/src/homeassistant/homeassistant/components/zha/core/gateway.py", line 214, in async_initialize
raise exc
File "/usr/src/homeassistant/homeassistant/components/zha/core/gateway.py", line 201, in async_initialize
await self.application_controller.startup(auto_form=True)
File "/usr/local/lib/python3.11/site-packages/zigpy/application.py", line 201, in startup
await self.shutdown()
File "/usr/local/lib/python3.11/site-packages/zigpy/application.py", line 406, in shutdown
await self._dblistener.shutdown()
File "/usr/local/lib/python3.11/site-packages/zigpy/appdb.py", line 187, in shutdown
await self._set_isolation_level(None)
File "/usr/local/lib/python3.11/site-packages/zigpy/appdb.py", line 205, in _set_isolation_level
await self._db._execute(lambda: setattr(self._db, "isolation_level", level))
File "/usr/local/lib/python3.11/site-packages/aiosqlite/core.py", line 126, in _execute
raise ValueError("Connection closed")
ValueError: Connection closed
