Thanks for the reply. With this new location. How do we remove a device that was not previously paired in HA. Let’s say an old device, from Smarthing, that needs to be “removed” first before it can pair again.
TBH, I’m not sure there is anything like that necessary for zigbee.
i think all you need to do is put the device back into pairing mode and try to pair it and I think it should work.
If not the you could try to put it back to factory default settings and that will make it ready to pair again without the need to remove it from the previous controller.
I know that is the case with zwave devices. Zigbee could be the same.
