This is a good alternative, SLAVA UKRAJINI!
https://www.ebay.com/itm/165178757770
async_initialize: all attempts have failed error after update to 2002.4.1
### The problem After upgrading to 2022.4.2, I get the following error at boo…tup. Zigbee hardwired devices are offline, battery operated devices seem to be ok. Zigbee hardwired devices needed to be re-booted before showing up again. Subsequent restarts of Home Assistant still have the same error, but hardwired and battery zigbee devices are both ok. [0x09D1:1:0x0006]: async_initialize: all attempts have failed: [DeliveryError('[0x09d1:1:0x0006]: Message send failure'), DeliveryError('[0x09d1:1:0x0006]: Message send failure'), DeliveryError('[0x09d1:1:0x0006]: Message send failure'), DeliveryError('[0x09d1:1:0x0006]: Message send failure')] ### What version of Home Assistant Core has the issue? 2022.4.1 ### What was the last working version of Home Assistant Core? 2022.3.8 ### What type of installation are you running? Home Assistant OS ### Integration causing the issue ZHA ### Link to integration documentation on our website https://www.home-assistant.io/integrations/zha ### Diagnostics information _No response_ ### Example YAML snippet _No response_ ### Anything in the logs that might be useful for us? ```txt Logger: homeassistant.components.zha.core.channels.base Source: components/zha/core/channels/base.py:457 Integration: Zigbee Home Automation (documentation, issues) First occurred: 12:51:22 PM (1 occurrences) Last logged: 12:51:22 PM [0x09D1:1:0x0006]: async_initialize: all attempts have failed: [DeliveryError('[0x09d1:1:0x0006]: Message send failure'), DeliveryError('[0x09d1:1:0x0006]: Message send failure'), DeliveryError('[0x09d1:1:0x0006]: Message send failure'), DeliveryError('[0x09d1:1:0x0006]: Message send failure')] ``` ### Additional information _No response_
