ZHA crashed and refuses to be reinstalled
Hello all,
For some unknown reason I can’t put my finger on, the Zigbee integration in my HASS stopped working. Did it stop since the last core update? Did it stop since an automated firmware update? It only happened in the last couple of days when I noticed by mailbox (the physical one next to the street) was full and I didn’t get any notification.
I’ve already (desperately) uninstalled the Zigbee integration completely, reverted the firmware update, but no luck. Even worse, when I now try to link the Zigbee coordinator (SLZB-06):
I’m running HA core 2024.7.4 in a Supervisor 2024.06.2 with OS 12.4.
This it the logfile from when I try to make the connection to the coordinator:
Logger: aiohttp.server
Bron: /usr/local/lib/python3.12/site-packages/aiohttp/web_protocol.py:421
Eerst voorgekomen: 08:36:01 (6 gebeurtenissen)
Laatst gelogd: 11:57:22
Error handling request
  File "/usr/local/lib/python3.12/site-packages/zigpy_znp/nvram.py", line 177, in osal_read
    read_rsp = await self.znp.request(
  File "/usr/local/lib/python3.12/site-packages/zigpy_znp/api.py", line 1069, in request
    raise InvalidCommandResponse(
zigpy_znp.exceptions.InvalidCommandResponse: Expected SRSP response SYS.OSALNVReadExt.Rsp(Status=<Status.SUCCESS: 0>, Value=None), got SYS.OSALNVReadExt.Rsp(Status=<Status.INVALID_PARAMETER: 2>, Value=b'')
  File "/usr/local/lib/python3.12/site-packages/aiohttp/web_protocol.py", line 452, in _handle_request
    resp = await request_handler(request)
  File "/usr/local/lib/python3.12/site-packages/aiohttp/web_app.py", line 543, in _handle
    resp = await handler(request)
  File "/usr/local/lib/python3.12/site-packages/aiohttp/web_middlewares.py", line 114, in impl
    return await handler(request)
  File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 92, in security_filter_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 210, in forwarded_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 26, in request_context_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 85, in ban_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 242, in auth_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/headers.py", line 32, in headers_middleware
    response = await handler(request)
  File "/usr/src/homeassistant/homeassistant/helpers/http.py", line 73, in handle
    result = await handler(request, **request.match_info)
  File "/usr/src/homeassistant/homeassistant/components/http/decorators.py", line 81, in with_admin
    return await func(self, request, *args, **kwargs)
  File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 222, in post
    return await super().post(request, flow_id)
  File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 74, in wrapper
    return await method(view, request, data, *args, **kwargs)
  File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 122, in post
    result = await self._flow_mgr.async_configure(flow_id, data)
  File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 368, in async_configure
    result = await self._async_configure(flow_id, user_input)
  File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 415, in _async_configure
    result = await self._async_handle_step(
  File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 518, in _async_handle_step
    result: _FlowResultT = await getattr(flow, method)(user_input)
  File "/usr/src/homeassistant/homeassistant/components/zha/config_flow.py", line 281, in async_step_manual_port_config
    return await self.async_step_verify_radio()
  File "/usr/src/homeassistant/homeassistant/components/zha/config_flow.py", line 326, in async_step_verify_radio
    return await self.async_step_choose_formation_strategy()
  File "/usr/src/homeassistant/homeassistant/components/zha/config_flow.py", line 342, in async_step_choose_formation_strategy
    await self._radio_mgr.async_load_network_settings()
  File "/usr/src/homeassistant/homeassistant/components/zha/radio_manager.py", line 255, in async_load_network_settings
    await app.load_network_info()
  File "/usr/local/lib/python3.12/site-packages/zigpy_znp/zigbee/application.py", line 144, in load_network_info
    await self._znp.load_network_info(load_devices=load_devices)
  File "/usr/local/lib/python3.12/site-packages/zigpy_znp/api.py", line 239, in load_network_info
    await self._load_network_info(load_devices=load_devices)
  File "/usr/local/lib/python3.12/site-packages/zigpy_znp/api.py", line 143, in _load_network_info
    key_desc = await self.nvram.osal_read(
  File "/usr/local/lib/python3.12/site-packages/zigpy_znp/nvram.py", line 191, in osal_read
    raise SecurityError(
zigpy_znp.exceptions.SecurityError: NV item cannot be read due to security constraints: <OsalNvIds.NWK_ACTIVE_KEY_INFO: 58>
I’m hoping someone can shed some light in the darkness. Literally too.
