I’m developing a custom radio board (ZigBee + BT LE + Z-Wave) which probably will be connected to the main device by SPI. The first element which I would like to implement for testing is zigbee communication. From my research, it appears that I must create a custom radio module (library) based on zigpy library to support my device in ZHA. And I have a few problems with this because I can’t find these things in any documentation:
- What methods and functionalities my library must have or override to successfully cooperate with ZHA ?
- What type of data ZHA (or zigpy) request from the radio module (raw frames, an array of decoded data, or something else)?
- Which methods are responsible for sending, receiving, and passing through data to ZHA ? (I could then make reverse engineering of existing radio modules)
I would be really thankful for the help because zigpy uses so many inheritances and external values, that is really hard to follow and understand code by own.
