Hello folks.
I’m using hassio in a docker on Ubuntu.
Conbee2
ZHA integration
I have a lot of xiaomi sensors and from what I’ve read, this package is needed to add more features to my sensors (eg battery level).
https://pypi.org/project/zha-quirks/#history.
I saw the guidlines but I have some doubts:
* Create a device class extending CustomDevice or a derivitave of it
* Use an existing handler as a guide. signature and replacement dicts are required. Include the SimpleDescriptor entry for each endpoint in the signature dict above the definition of the endpoint in this format:
I’m standing at this first point. My experience in ubuntu is minimal. Can you point me in a direction? Any documentation?
then at point 2, I think it is necessary to use the following file (for xiaomi door/window sensor)
I need to change the signature parameters, right? I replace the file and then execute it with the command:
$ python3 motion_aq2.py
Something is missing?
Thanks in advance
