I have two Apex Smart Plugs (Apex Smart Plug - Gjør dine enheter smartere | Eva - Smarthus gjort enkelt) that are giving the following warnings in my logs
2022-07-02 19:05:49 WARNING (MainThread) [zigpy.zcl] [0xF63C:1:0xfeed] Unknown cluster command 42 b''
2022-07-02 19:05:55 WARNING (MainThread) [zigpy.zcl] [0x3363:1:0xfeed] Unknown cluster command 42 b''
I’ve confirmed that 0xF63C and 0x3363 are the id’s of the two smart plugs.
They are connected via a Conbee II and ZHA
I’ve tried to reconfigure the devices, but that fails with the message “The device reconfiguration failed. Additional information may be available in the logs”.
Sometimes I get the following warning in the logs when I try to reconfigure:
2022-07-03 12:19:29 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0xF63C:1:0x1000]: Couldn't get list of groups: [0xf63c:1:0x1000]: Message send failure
I’ve also recently removed and re-added the device to ZHA, but the same warnings persist.
I have an identical plug connected via Zigbee2MQTT that is not giving the same warnings, although they just might not be exposed via Z2M.
Any idea what the issue could be?
