I’ve been having on and off issues with my IKEA smart blinds while connected to HASSIO Zigbee. I decided to move them over to Zigbee2MQTT, however while doing so, I removed the blinds and the repeaters from ZHA using the “Remove Device” link in the integration. The blinds instantly went away, but the repeaters seem to be stuck in limbo.
In doing a little research I found that I should be able to remove them from the core.entity_registry file but discovered that they are already gone. I also found some people had success using the ZHA remove service…but you need the ieee number which no longer shows up (see below).
Any suggestions on how to competely remove this device?
