TexTown
(Michel)
January 11, 2023, 2:17pm
21
I’ve managed to get dimming fixed
You can try the blueprint, download it here: A Home Assistant blueprint for ZHA to control lights using the EcoDim ED-10013 2 Channel Remote · GitHub
Please let me know if it works for you.
A community post for the 2 channel remote is now available as well:
Sandje
(Sander)
January 12, 2023, 2:26pm
22
I’ve edit the blueprint a little bit.
With the basics of the IKEA blueprint and the settings from @PaulAntonDeen and @TexTown .
Now I have a setup with all buttons (long and shot pressing) and using any action you want.
Have fun with it:).
i am trying to use the ecodim-10015, thinking just changing the model number in yaml bleuprint.
But when I am trying to save the yaml is says: Message malformed: extra keys not allowed @ data[‘blueprint’]
Anyone got the ecodim-10015 working?
Sandje
(Sander)
April 20, 2023, 1:34pm
24
I don’t know. In my oppinion you have to change only the model: ED-10014
to model: ED-10015
Maybe you can make an new Yaml. to copy all of it, and change it in your own yaml?
tik83
April 20, 2023, 2:32pm
25
This is my adjustment for the Blueprint.
Ecodim: ED-10013
blueprint:
name: ZHA - Ecodim, 2 Channel remote
description: Control any light using the Ecodim remote on ZHA
domain: automation
input:
remote:
name: Remote controller
description: Remote to use
selector:
device:
integration: zha
manufacturer: EcoDim
model: ED-10013
multiple: false
light_1:
name: Light row 1
description: The lights that will be controlled with row 1
selector:
entity:
domain: light
light_2:
name: Light row 2
description: The lights that will be controlled with row 2
selector:
entity:
domain: light
step_size:
description: The % step each dimming step takes
default: 10
selector:
number:
min: 5.0
max: 25.0
unit_of_measurement: '%'
mode: slider
step: 1.0
step_delay:
description: The time between dimming steps (ms)
default: 1000
selector:
number:
min: 100.0
max: 2000.0
unit_of_measurement: milliseconds
mode: slider
step: 1.0
source_url: https://gist.github.com/PaulAntonDeen/4089539eb42f7bcf11a945630c38fec4#file-zha_ecodim_remote_4_channel-yaml
mode: restart
max_exceeded: silent
- platform: event
event_type: zha_event
event_data:
device_id: !input remote
- variables:
command: '{{ trigger.event.data.command }}'
cluster_id: '{{ trigger.event.data.cluster_id }}'
endpoint_id: '{{ trigger.event.data.endpoint_id }}'
args: '{{ trigger.event.data.args }}'
step_size: !input step_size
- choose:
- conditions:
- '{{ command == ''on'' }}'
- '{{ cluster_id == 6 }}'
- '{{ endpoint_id == 1 }}'
sequence:
- service: light.turn_on
target: !input light_1
transition: 1
- conditions:
- '{{ command == ''off'' }}'
sequence:
- service: light.turn_off
transition: 1
- conditions:
- '{{ command == ''move_with_on_off'' }}'
- '{{ cluster_id == 8 }}'
- '{{ args == ''[<MoveMode.Up: 0>, 50]'' }}'
sequence:
repeat:
while:
- condition: template
value_template: '{{ repeat.index < (100 / step_size)|int }}'
sequence:
transition: 1
brightness_step_pct: !input step_size
- delay:
milliseconds: !input step_delay
- conditions:
- '{{ args == ''[<MoveMode.Down: 1>, 50]'' }}'
sequence:
repeat:
while:
sequence:
transition: 1
brightness_step_pct: '{{ step_size * -1 }}'
- delay:
- conditions:
- '{{ command == ''stop'' }}'
sequence:
- conditions:
- '{{ endpoint_id == 2 }}'
sequence:
target: !input light_2
transition: 1
- conditions:
sequence:
transition: 1
- conditions:
sequence:
repeat:
while:
sequence:
transition: 1
- delay:
- conditions:
sequence:
repeat:
while:
sequence:
transition: 1
- delay:
- conditions:
sequence:
It worked, had some problems with creating the automation.
anyone has a blueprint for zigbee2mqtt?
PeWi56
December 22, 2023, 2:29pm
28
I recently started using the Ecodim, 2 Channel remote Model ED-10012 without success.
When I operate group 1 button 1 nothing happens, group 1 button 0 nothing happens.
When I operate group 2 button 1, both lamps turn on, group 2 button 0 turns lamp 1 off, but only 2 remains on. This can only switch be disabled on the micro switch.
Can anyone help me or is this switch brokent?
Greetings PeWi56
anyone ? or is it possible to change from zha to z2mqtt ?
edit: found solution
Hurst
March 17, 2024, 6:20pm
30
Hey @antonov124 ,
can you please share your solution for zigbee2mqtt?
Thx
