ZHA - Ecosmart 4-button Zigbee Remote with Circadian Lighting
Summary
This blueprint allows you to control a smart light entity using an Ecosmart Zigbee Remote from Home Depot
Button Bindings
  1. Light ON/OFF, Circadian ON
  2. Light Brightness, Circadian OFF
  3. Light Temperature, Circadian OFF
  4. Circadian ON
Requirements
  • The blueprint toggles a circadian lighting switch off to prevent the circadian lighting from overriding manual brightness/color changes. I suggest creating a unique circadian lighting switch for each light/group controlled by each remote. I am using this integration, but it should work with any circadian integration with a switch. You could link this to a dummy switch if you don’t have circadian lighting set up and button 4 won’t do anything.
  • The bulb can be any brand that supports tunable white or color, I use the blueprint with the Ecosmart A19, Ecosmart BR30, Philips Hue + Color, Sylvania Lightify RGB BR30, and mixed light groups.
  • The remote is connected via Zigbee Home Automation (ZHA). The light(s) just need to be in Home Assistant, doesn’t matter if it is through ZHA, WiFi, etc.
Blueprint
blueprint:
  name: ZHA - Ecosmart Zigbee Remote with Circadian Lighting
  description: Control lights with an Ecosmart 4-button Zigbee remote
  domain: automation
  source_url: https://community.home-assistant.io/t/zha-ecosmart-4-button-zigbee-remote-with-circadian-lighting/265187
  input:
    light_target:
      description: Select which light or light group you wish to control
      selector:
        entity:
          domain: light
    device_ieee:
      description: To find this, listen for zha_event in Developer Tools > Events, then press a button on your remote and identify the value of "device_ieee". It should look like "xx:xx:xx:xx:xx:xx:xx:xx"
    circadian_switch:
      description: Add circadian lighting to button 4. It will turn off with brightness/color control and turn on with the on/off toggle and bottom button
      selector:
       entity:
          domain: switch
mode: restart
- platform: event
  event_type: zha_event
  event_data:
    device_ieee: !input device_ieee
condition: []
- variables:
    command: '{{ trigger.event.data.command }}'
    args: '{{ trigger.event.data.args }}'
- choose:
  - conditions:
    - condition: or
      conditions:
      - condition: template
        value_template: '{{ command == ''on'' }}'
        value_template: '{{ command == ''off'' }}'
    sequence:
    - service: light.toggle
      entity_id: !input light_target
      data: {}
    - service: switch.turn_on
      entity_id: !input circadian_switch
      data: {}
  - conditions:
      value_template: '{{ command == ''move_to_level'' }}'
    sequence:
    - entity_id: !input light_target
      service: light.turn_on
      data_template:
        brightness: '{{ args[0]|int }}'
    - service: switch.turn_off
      data: {}
  - conditions:
      value_template: '{{ command == ''move_to_color_temp'' }}'
    sequence:
    - service: light.turn_on
      data_template:
        color_temp: '{{ args[0]|int }}'
      data: {}
  - conditions:
      value_template: '{{ command == ''move_to_level_with_on_off'' }}'
    sequence:
      data: {}
I was getting a ‘but no default was specified’ error, which I think is related to a change in templates that occurred with 2021.10.x
I made some updates to fix the issue:
blueprint:
  domain: automation
  input:
    light_target:
      selector:
        entity:
          domain: light
          multiple: false
    device_ieee:
    circadian_switch:
      selector:
        entity:
          domain: switch
          multiple: false
mode: restart
- platform: event
  event_data:
condition: []
- variables:
- choose:
  - conditions:
    - condition: or
      conditions:
    sequence:
      data: {}
      data: {}
  - conditions:
    sequence:
      data_template:
        brightness: '{{ int(trigger.event.data.params.level,254) }}'
      data: {}
  - conditions:
    sequence:
      data_template:
        color_temp: '{{ int(trigger.event.data.params.color_temp_mireds, 286) }}'
      data: {}
  - conditions:
    sequence:
      data: {}
how are you guys getting the remote paired into ZHA? holding the 1st and 3rd button seems to be putting it into pairing, but my conbee2 never finds it. i have a ton of those ecosmart bulbs around the house
It took me several tries to get them to pair. Do the reset and then press one of the other buttons to keep it awake while the hub interviews/pairs.
