ZHA / Enable Custom Quirks /
I am trying to enable/use a custom quirk for an aquara device (lumi.switch.l2aeu1) but it seems that ZHA is not even trying to use it.
Can someone check if I at least got config.yaml correct?
HA on RaspPI 4
Home Assistant 2023.4.1
Supervisor 2023.04.0
Operating System 9.5
Frontend 20230406.1 - latest
ZHA/Sky Connect
Config Yaml:
When pairing the device the log says:
So it seems to me: that it is checking not only Standard zha database but also Quirks database (good) but not my custom Quirks database. Why?
I am not even sure yet if the custom quirk works, but i can not see if it tries to apply it.
Thank you!
Lukas
I am having the same issue. I would like to get my new device working, but I can’t get any feedback that my custom quirk is being read. I just put some bogus info in the quirk file to try to get an error or a crash, but nothing. Did you ever have any success with this?
