I have noticed that recently zha_event seems to work only when it wants to. I have an outlet:
"node_descriptor": "NodeDescriptor(logical_type=<LogicalType.Router: 1>, complex_descriptor_available=0, user_descriptor_available=0, reserved=0, aps_flags=0, frequency_band=<FrequencyBand.Freq2400MHz: 8>, mac_capability_flags=<MACCapabilityFlags.AllocateAddress|RxOnWhenIdle|MainsPowered|FullFunctionDevice: 142>, manufacturer_code=0, maximum_buffer_size=80, maximum_incoming_transfer_size=160, server_mask=0, maximum_outgoing_transfer_size=160, descriptor_capability_field=<DescriptorCapability.NONE: 0>, *allocate_address=True, *is_alternate_pan_coordinator=False, *is_coordinator=False, *is_end_device=False, *is_full_function_device=True, *is_mains_powered=True, *is_receiver_on_when_idle=True, *is_router=True, *is_security_capable=False)",
"endpoints": {
"1": {
"profile_id": 49246,
"device_type": "0x0010",
"in_clusters": [
"0x0000",
"0x0003",
"0x0004",
"0x0005",
"0x0006"
"out_clusters": [
"0x0000"
"manufacturer": "eWeLink",
"model": "SA-003-Zigbee",
"class": "zigpy.device.Device"
I can control this outlet from HA. It shows up in Lovelace correctly, and it responds accordingly when I manually turn the outlet on and off. But when I listen for it in developer->events, the messages don’t show up. This isn’t the only device like this on my network. This outlet is about 10ft (3m) from my laptop with the zigbee controller. I do get some messages when I listen to zha_event, but not all of them. Weird.
