An automation blueprint to display a fan speed on the LED notification bar on the Inovelli VZM31-SN or VZM35-SN Blue Series 2-1 Switch via ZHA.
The Inovelli VZM31-SN or VZM35-SN Blue Series 2-1 Switch comes with seven (7) LED lights in a strip on the right side of the faceplate (below the small config button). We can display a representation of a fan speed between a minimum and maximum value.
Features
- Display a fan speed as a percentage between 0 and 100 percent.
- Customize color (default: red), intensity (default: 50%) and duration (default: always on) of the LED display.
Requirements
- ZHA
- An Inovelli VZM31-SN (light) or VZM35-SN (fan) Blue Series 2-1 Switch added to your ZigBee network in Home Assistant
- A fan in your Home Assistant to pull a speed from
Blueprint
blueprint:
name: Inovelli LED Fan Speed Display
description: Display the fan speed on the LED strip of an Inovelli VZM35-SN light switch
source_url: https://codeberg.org/nwithan8/home-assistant-contributions/raw/branch/main/blueprints/automations/inovelli_led_fan_speed.yaml
domain: automation
input:
fan:
description: The fan to monitor
selector:
entity:
domain:
- fan
multiple: false
switch:
description: Which light switch to program
selector:
device:
filter:
- integration: zha
manufacturer: Inovelli
model: VZM31-SN
- integration: zha
model: VZM35-SN
duration:
description: How long the effect should last, in seconds (1-254, 255 for indefinite)
selector:
number:
min: 1
max: 255
default: 255
level:
description: How intense the light should be, percentage (0-100)
selector:
number:
min: 0
max: 100
default: 50
color:
description: The color the light should be, (0-254, 255 for white)
selector:
number:
min: 0
max: 255
mode: box
default: 0
mode: single
max_exceeded: silent
variables:
fan: !input fan
speed: "{{ state_attr(fan, 'percentage') | float(0) | round(1) }}"
solid_led_effect_code: 1
off_led_effect_code: 0
led_command: 3 # Set individual LED
min_speed: 0
max_speed: 100
level: !input level
duration: !input duration
switch: !input switch
color: !input color
off_color: 255 # White
speed_range: "{{ max_speed - min_speed }}"
led_range: 7
leds_to_turn_on: "{{ (speed - min_speed) / speed_range * led_range | round(0) | int }}"
platform: state
entity_id: !input fan
- repeat:
count: "{{ led_range }}"
sequence:
- service: zha.issue_zigbee_cluster_command
ieee: >
{{ (device_attr(switch, "identifiers")|list).0.1 }}
endpoint_id: 1
cluster_id: 64561
cluster_type: in
command: "{{ led_command }}"
command_type: server
# Index starts at 1 like an idiot
params:
"led_number": "{{ repeat.index - 1 }}"
"led_effect": >
{%- if leds_to_turn_on > 0 and repeat.index - 1 <= leds_to_turn_on -%}
{{ solid_led_effect_code }}
{%- else -%}
{{ off_led_effect_code }}
{%- endif -%}
"led_color": >
{{ color }}
{%- else -%}
{{ off_color }}
{%- endif -%}
"led_level": "{{ level }}"
"led_duration": "{{ duration }}"
manufacturer: 4655
Install
- Click the “Import Blueprint” button above and follow the instructions to import the blueprint into your Home Assistant.
- Click “Create Automation” from the Blueprint.
- Select a
Fanto monitor. The speed reported by this fan will determine the display on your light switch.- This automation will run every time the fan state is updated.
- Select a target Inovelli light switch to change the LEDs of.
- (Optional) Change the duration, in seconds, of the LED illuminance.
- By default, the LEDs are always on (255)
- (Optional) Change the intensity of the LED illuminance.
- By default, the LEDs illuminate to 50% brightness
- (Optional) Change the color of the LEDs
- Use this calculator to determine color value.
- By default, the LEDs are solid red (0)
- Click “Save” to save your automation.
Usage
When the speed reported by the selected fan changes, this automation will be triggered, illuminating some or all of the LEDs on the selected Inovelli light switch.
The LEDs illuminate in bottom-up order. The higher the speed, the more LEDs illuminated, and vice versa.
Changelog
January 6, 2025: Expand/improve Inovelli switch model filter
April 27, 2024: Initial release
