Hi, I am hoping someone can help me out here. I am completely stuck.
My situation is as follows:
- Bought a Sonoff Zigbee bridge pro
- Flashed it with Tasmota (12.4.0.2)
- Followed this guide by Mat Zolnierczyk → Resized FS → Flashed Coordinator firmware → rebooted device
So far so good, I am able to pair my Zigbee sensors in Tasmota and can read the temperature of my Sonoff Zigbee temperature sensor.
From here on I am following this page to enable my Sonoff Zigbee bridge pro for the ZHA integration.
- Select Sonoff ZBPro TCP in the Tasmota Auto Configuration section
- Confirmed that TCP port 8888 is listening on my Zigbee Bridge
- In the ZHA integration, I selected ZNP as radio type
- Configured socket://192.168.0.9:8888 as my serial path and selected software for Data Flow control
The Network Formation popup looks promising (see below), but regardless of selecting “Keep radio network settings” or “Erase network settings and create a new network”…
…both will end in an “ERROR”
Yesterday I did my first attempt, and it worked right away and my sensors were visible in HA. Both my Zigbee sensors stopped reporting after 30 minutes already. All my attempts to fix or reproduce the issue today failed. I am stuck in getting the ZHA integration to work.
The error in the homeassistant log for this is not helpful:
2023-03-15 22:53:46.696 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry socket://192.168.0.9:8888 for zha
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 383, in async_setup
result = await component.async_setup_entry(hass, self)
File "/usr/src/homeassistant/homeassistant/components/zha/__init__.py", line 122, in async_setup_entry
await zha_gateway.async_initialize()
File "/usr/src/homeassistant/homeassistant/components/zha/core/gateway.py", line 185, in async_initialize
self.application_controller = await app_controller_cls.new(
File "/usr/local/lib/python3.10/site-packages/zigpy/application.py", line 171, in new
await app.startup(auto_form=auto_form)
File "/usr/local/lib/python3.10/site-packages/zigpy/application.py", line 146, in startup
await self.initialize(auto_form=auto_form)
File "/usr/local/lib/python3.10/site-packages/zigpy/application.py", line 122, in initialize
await self.start_network()
File "/usr/local/lib/python3.10/site-packages/zigpy_znp/zigbee/application.py", line 196, in start_network
await self._znp.migrate_nvram()
File "/usr/local/lib/python3.10/site-packages/zigpy_znp/api.py", line 595, in migrate_nvram
await self.reset()
File "/usr/local/lib/python3.10/site-packages/zigpy_znp/api.py", line 606, in reset
await self.request_callback_rsp(
File "/usr/local/lib/python3.10/site-packages/zigpy_znp/api.py", line 1043, in request_callback_rsp
return await callback_rsp
asyncio.exceptions.CancelledError
Any suggestion or pointer in the right direction is welcome.
I am running:
Home Assistant 2023.3.4
Supervisor 2023.03.1
Operating System 9.5
Frontend 20230309.0 - latest
