Hello! My first blueprint, so one to share with you.
Features:
Using ZHA, use this blueprint to listen for events from a Hue Dimmer RWL022 switch. Bind two light entities to the switch, one for the power button and one for the hue button. For example, have your main light bound to the power button and your lamps bound to the hue button. Then you can turn both lights on an off independently and use the middle dimmer buttons to dim the lights, depending on which lights are on at the time. With both lights turned off, press the dimmer up button once to set both lights to a low brightness. Good for walking around at night.
Requires;
- Hue Dimmer Switch, RWL022 (UK Version 2 Switch)
- Two objects in Home Assistant under the domain ‘light’.
- Integration for the Dimmer Switch using ZHA. It cannot be imported using another method.
blueprint:
name: Philips Hue Dimmer RWL022
description:
"Control lights with a Philips Hue Dimmer Switch (v2).\n\n Blueprint\
\ Version: 1"
domain: automation
input:
remote:
name: Philips Hue Dimmer Switch
description: Pick a RWL022 Dimmer Switch
selector:
device:
integration: zha
entity:
domain: sensor
device_class: battery
power_light:
name: The main light entity to control.
description: The light entity which the top button will control. (Power button).
selector:
entity:
domain: light
hue_light:
name: The secondary light entity to control.
description: The light entity which the bottom button will control. (hue button).
selector:
entity:
domain: light
source_url: https://gist.github.com/ODickins/eb3fdfd52af13d4511ff6f1b2a5952f6
mode: restart
max_exceeded: silent
variables:
power_light: !input "power_light"
hue_light: !input "hue_light"
- platform: event
event_type: zha_event
event_data:
device_id: !input "remote"
cluster_id: 64512
- variables:
command: "{{ trigger.event.data.command }}"
power_light_on: "{{ states(power_light) == 'on' }}"
hue_light_on: "{{ states(hue_light) == 'on' }}"
- choose:
- conditions: "{{ command == 'on_press' }}"
sequence:
- choose:
- conditions:
- "{{ power_light_on == true }}"
sequence:
service: light.turn_off
entity_id: !input "power_light"
transition: 1
- conditions:
- "{{ power_light_on == false }}"
sequence:
service: light.turn_on
transition: 1
brightness: 255
- conditions: "{{ command == 'off_press' }}"
sequence:
- choose:
- conditions:
- "{{ hue_light_on == true }}"
sequence:
entity_id: !input "hue_light"
transition: 1
- conditions:
- "{{ hue_light_on == false }}"
sequence:
transition: 1
brightness: 255
- conditions:
- condition: or
conditions:
- "{{ command == 'up_press' }}"
- "{{ command == 'up_hold' }}"
sequence:
- choose:
- conditions:
sequence:
entity_id:
- !input "power_light"
- !input "hue_light"
transition: 1
brightness: 26
- conditions:
sequence:
entity_id:
transition: 1
brightness_step: 25
- conditions:
sequence:
entity_id:
transition: 1
brightness_step: 25
- conditions:
sequence:
entity_id:
transition: 1
brightness_step: 25
- conditions:
- condition: or
conditions:
- "{{ command == 'down_press' }}"
- "{{ command == 'down_hold' }}"
sequence:
- choose:
- conditions:
sequence:
entity_id:
transition: 1
brightness_step: -25
- conditions:
sequence:
entity_id:
transition: 1
- conditions:
sequence:
entity_id:
transition: 1
Hi.
