ZHA IKEA E2123 Symfonisk Gen2 Remote (Customisable)
Here is a simple blueprint that allows you to set up 11 commands for the Ikea Symfonisk Sound Remote (Gen 2, square remote with 7 buttons).
2 Shortcut buttons can have separate commands for single press, double press & hold.
The media control buttons don’t differentiate double press or hold.
blueprint:
  name: ZHA - IKEA E2123 Symfonisk GEN2 remote
  description: Set up custom commands for each button on the Ikea Symfonisk
    Gen 2 Remote. The 2 shortcut buttons also have seperate functions for
    double press and hold.
  domain: automation
  input:
    remote:
      description: IKEA Symfonisk controller GEN2 to use
      selector:
        device:
          integration: zha
          manufacturer: IKEA of Sweden
          model: SYMFONISK sound remote gen2
          multiple: false
    action_play:
      name: Play button press
      description: Action to run on play button press.
      default: []
      selector:
        action: {}
    action_vol_up:
      name: Volume Up button press
      description: Action to run on volume up button press.
      default: []
      selector:
        action: {}
    action_vol_down:
      name: Volume Down button press
      description: Action to run on volume down button press.
      default: []
      selector:
        action: {}
    action_next:
      name: Next button press
      description: Action to run on next button press.
      default: []
      selector:
        action: {}
    action_previous:
      name: Previous button press
      description: Action to run on previous button press.
      default: []
      selector:
        action: {}
    action_1,1:
      name: Shortcut 1 button press
      description: Action to run on shortcut 1 button single press.
      default: []
      selector:
        action: {}
    action_1,2:
      name: Shortcut 1 button double press
      description: Action to run on shortcut 1 button double press.
      default: []
      selector:
        action: {}
    action_1,3:
      name: Shortcut 1 button hold
      description: Action to run on shortcut 1 button hold.
      default: []
      selector:
        action: {}
    action_2,1:
      name: Shortcut 2 button press
      description: Action to run on shortcut 2 button single press.
      default: []
      selector:
        action: {}
    action_2,2:
      name: Shortcut 2 button double press
      description: Action to run on shortcut 2 button double press.
      default: []
      selector:
        action: {}
    action_2,3:
      name: Shortcut 2 button hold
      description: Action to run on shortcut 2 button hold.
      default: []
      selector:
        action: {}
mode: single
max_exceeded: silent
- platform: event
  event_type: zha_event
  event_data:
    device_id: !input remote
- variables:
    command: '{{ trigger.event.data.command }}'
    cluster_id: '{{ trigger.event.data.cluster_id }}'
    endpoint_id: '{{ trigger.event.data.endpoint_id }}'
    args: '{{ trigger.event.data.args }}'
    action_play: !input action_play
    action_vol_up: !input action_vol_up
    action_vol_down: !input action_vol_down
    action_next: !input action_next
    action_previous: !input action_previous
    action_1,1: !input action_1,1
    action_1,2: !input action_1,2
    action_1,3: !input action_1,3
    action_2,1: !input action_2,1
    action_2,2: !input action_2,2
    action_2,3: !input action_2,3
- choose:
  - conditions:
    - '{{ command == ''toggle'' }}'
    - '{{ cluster_id == 6 }}'
    - '{{ endpoint_id == 1 }}'
    sequence: !input action_play
  - conditions:
    - '{{ command == ''step'' }}'
    - '{{ cluster_id == 8 }}'
    - '{{ trigger.event.data.params.step_mode == 0 }}'
    sequence: !input action_next
  - conditions:
    - '{{ trigger.event.data.params.step_mode == 1 }}'
    sequence: !input action_previous
  - conditions:
    - '{{ command == ''move_with_on_off'' }}'
    - '{{ trigger.event.data.params.move_mode == 0}}'
    sequence: !input action_vol_up
  - conditions:
    - '{{ trigger.event.data.params.move_mode == 1 }}'
    sequence: !input action_vol_down
  - conditions:
    - '{{ command == ''shortcut_v1_events'' }}'
    - '{{ trigger.event.data.args == [1, 1] }}'
    sequence: !input action_1,1
  - conditions:
    - '{{ trigger.event.data.args == [1, 2] }}'
    sequence: !input action_1,2
  - conditions:
    - '{{ trigger.event.data.args == [1, 3] }}'
    sequence: !input action_1,3
  - conditions:
    - '{{ trigger.event.data.args == [2, 1] }}'
    sequence: !input action_2,1
  - conditions:
    - '{{ trigger.event.data.args == [2, 2] }}'
    sequence: !input action_2,2
  - conditions:
    - '{{ trigger.event.data.args == [2, 3] }}'
    sequence: !input action_2,3
I think you want this in the blueprint exchange. This thread is for help and troubleshooting mostly…
With the remote updated to 0x01000035 the dot buttons stopped working. Had to change the conditions. Here is my full config based on original.
blueprint:
  description:
    Set up custom commands for each button on the Ikea Symfonisk Gen 2
    Remote. The 2 shortcut buttons also have seperate functions for double press and
    hold.
  domain: automation
  input:
    remote:
      selector:
        device:
          integration: zha
          multiple: false
    action_play:
      default: []
      selector:
        action: {}
    action_vol_up:
      default: []
      selector:
        action: {}
    action_vol_down:
      default: []
      selector:
        action: {}
    action_next:
      default: []
      selector:
        action: {}
    action_previous:
      default: []
      selector:
        action: {}
    action_1,1:
      default: []
      selector:
        action: {}
    action_1,2:
      default: []
      selector:
        action: {}
    action_1,3:
      default: []
      selector:
        action: {}
    action_2,1:
      default: []
      selector:
        action: {}
    action_2,2:
      default: []
      selector:
        action: {}
    action_2,3:
      default: []
      selector:
        action: {}
  source_url: https://community.home-assistant.io/t/zha-ikea-e2123-symfonisk-gen2-remote-customisable/584626
mode: single
  - platform: event
    event_data:
  - variables:
      command: "{{ trigger.event.data.command }}"
      cluster_id: "{{ trigger.event.data.cluster_id }}"
      endpoint_id: "{{ trigger.event.data.endpoint_id }}"
      args: "{{ trigger.event.data.args }}"
  - choose:
      - conditions:
          - "{{ command == 'toggle' }}"
          - "{{ cluster_id == 6 }}"
          - "{{ endpoint_id == 1 }}"
      - conditions:
          - "{{ command == 'step' }}"
          - "{{ cluster_id == 8 }}"
          - "{{ trigger.event.data.params.step_mode == 0 }}"
      - conditions:
          - "{{ trigger.event.data.params.step_mode == 1 }}"
      - conditions:
          - "{{ command == 'move_with_on_off' }}"
          - "{{ trigger.event.data.params.move_mode == 0}}"
      - conditions:
          - "{{ command == 'short_release' }}"
          - "{{ endpoint_id == 2 }}"
      - conditions:
          - "{{ command == 'multi_press_complete' }}"
      - conditions:
          - "{{ command == 'long_release' }}"
      - conditions:
          - "{{ endpoint_id == 3 }}"
      - conditions:
      - conditions:
Hi @enriquegh , and thanks for the code. I’m not a developer, but could it be that a section for “action vol down” is missing?
I cant chose my remote. HA says, no device found. May it be, that this Blueprint is only for zha, not z2mqtt?
