This blueprint is extended version for controlling lights and switches with the IKEA four button remote (the square ones), integrated via ZHA.
It extends @Malte's version (no switches) which is extending @SwerveShot’s version (incomplete and hasn’t seen any recent activity) which is based on the work of @frenck with the five button version.
Pressing the up button will turn on the lights at the last set brightness (unless the force brightness is toggled on in the blueprint) and turn on configured switches.
Pressing the down button will turn the lights and switches off again.
Pressing and holding the up/down buttons will change the brightness smoothly and can be pressed and hold until the brightness is satisfactory.
The “left” and “right” buttons can be assigned to a short and long button press action. This allows you to assign, e.g., a scene or anything else. Use the left and right button events with care, as before the long press event is sent, the “on” event gets triggered.
This is what the Blueprint looks like from the UI:
Blueprint Code
Click the badge to import this Blueprint: (needs Home Assistant Core 2021.3 or higher)
Or import this Blueprint by using the forum topic URL:
blueprint:
name: IKEA four button remote for switches and lights
description: 'Control lights and switches with an IKEA four button remote (the square ones),
for use with [ZHA](https://www.home-assistant.io/integrations/zha/).
Extends [Malte](https://community.home-assistant.io/u/Malte)''s [version](https://community.home-assistant.io/t/zha-ikea-four-button-remote-styrbar-for-lights-e2001-e2002/384482)
which is based on [SwerveShot](https://community.home-assistant.io/u/SwerveShot)''s [version](https://community.home-assistant.io/t/zha-ikea-four-button-remote-for-lights/347657)
which is based on the work of [frenck](https://community.home-assistant.io/u/frenck)
the force brightness is toggled on in the blueprint) and turn on selected switches.
Pressing the down button will turn the lights off again and turn off selected switches.
The "left" and "right" buttons can be assigned to a short and long button press
"on" event gets triggered.
domain: automation
input:
remote:
description: IKEA remote to use
selector:
device:
integration: zha
manufacturer: IKEA of Sweden
model: Remote Control N2
switch:
description: The switch(es) to control
selector:
entity:
domain: switch
light:
description: The light(s) to control
selector:
entity:
domain: light
force_brightness:
name: Force turn on brightness
description: Force the brightness to the set level below, when the "on" button
on the remote is pushed and lights turn on.
default: false
selector:
boolean: {}
brightness:
description: Brightness of the light(s) when turning on
default: 100
selector:
number:
min: 0.0
max: 100.0
mode: slider
step: 1.0
unit_of_measurement: '%'
button_left_short:
name: Left button - short press
description: Action to run on short left button press
default: []
selector:
action: {}
button_left_long:
name: Left button - long press
description: Action to run on long left button press. Use with care, as before
the long press event is sent, the "on" event gets triggered.
default: []
selector:
action: {}
button_right_short:
name: Right button - short press
description: Action to run on short right button press
default: []
selector:
action: {}
button_right_long:
name: Right button - long press
description: Action to run on long right button press. Use with care, as before
default: []
selector:
action: {}
source_url: https://community.home-assistant.io/t/zha-ikea-four-button-remote-styrbar-for-lights-and-switches/395248
mode: restart
max_exceeded: silent
variables:
force_brightness: !input 'force_brightness'
- platform: event
event_type: zha_event
event_data:
device_id: !input 'remote'
- variables:
command: '{{ trigger.event.data.command }}'
cluster_id: '{{ trigger.event.data.cluster_id }}'
endpoint_id: '{{ trigger.event.data.endpoint_id }}'
args: '{{ trigger.event.data.args }}'
- choose:
- conditions:
- '{{ command == ''on'' }}'
- '{{ cluster_id == 6 }}'
- '{{ endpoint_id == 1 }}'
sequence:
- choose:
- conditions: '{{ force_brightness }}'
sequence:
- service: light.turn_on
target: !input 'light'
brightness_pct: !input 'brightness'
- service: switch.turn_on
target: !input 'switch'
default:
- conditions:
- '{{ command == ''off'' }}'
sequence:
- service: light.turn_off
- service: switch.turn_off
- conditions:
- '{{ command == ''move_with_on_off'' }}'
- '{{ cluster_id == 8 }}'
- '{{ args == [0, 83] }}'
sequence:
- repeat:
count: 10
sequence:
brightness_step_pct: 10
transition: 1
- delay: 0.5
- conditions:
- '{{ command == ''move'' }}'
- '{{ args == [1, 83] }}'
sequence:
- repeat:
count: 10
sequence:
brightness_step_pct: -10
transition: 1
- delay: 0.5
- conditions:
- '{{ command == ''press'' }}'
- '{{ cluster_id == 5 }}'
- '{{ args == [257, 13, 0] }}'
sequence: !input 'button_left_short'
- conditions:
- '{{ command == ''hold'' }}'
- '{{ args == [3329, 0] }}'
sequence: !input 'button_left_long'
- conditions:
- '{{ args == [256, 13, 0] }}'
sequence: !input 'button_right_short'
- conditions:
- '{{ args == [3328, 0] }}'
sequence: !input 'button_right_long'
