blueprint:
name: ZHA - IKEA Tradfri On/Off Dimming Control Only
description:
"Dimming-Only control with IKEA Tradfri on/off switch
Single click on/off should be handled by other automations to allow cycling between light configurations/modes"
domain: automation
input:
remote:
description: The remote that will control the lights
selector:
device:
integration: zha
manufacturer: 'IKEA of Sweden'
model: 'TRADFRI on/off switch'
light:
description: The lights that will be controlled
selector:
entity:
domain: light
mode: restart
- platform: event
event_type: zha_event
event_data:
device_id: !input 'remote'
- variables:
command: "{{ trigger.event.data.command }}"
cluster_id: "{{ trigger.event.data.cluster_id }}"
endpoint_id: "{{ trigger.event.data.endpoint_id }}"
- choose:
- conditions:
- "{{ command == 'move_with_on_off' }}"
- "{{ cluster_id == 8 }}"
- "{{ endpoint_id == 1 }}"
sequence:
repeat:
while:
- condition: template
value_template: "{{ repeat.index < 10 }}"
sequence:
- service: light.turn_on
target: !input 'light'
transition: 1
brightness_step_pct: 15
- delay: 1
- conditions:
- "{{ command == 'move' }}"
sequence:
repeat:
while:
sequence:
transition: 1
brightness_step_pct: -15
- delay: 1
- conditions:
- "{{ command == 'stop' }}"
sequence:
