ZHA - IKEA Somrig remote for lights with double press
A blueprint for the IKEA Somrig remote, model E2213, to be used with ZHA as a light control (with dimming, etc) and a double press configuration. This expands usual basic Somrig blueprint with more Styrbar like functionality.
Enjoy : )
blueprint:
  name: ZHA - IKEA Somrig remote for lights
  description: Dimmable light control
  domain: automation
  input:
    remote:
      description: IKEA Somrig remote to use
      selector:
        device:
          integration: zha
          manufacturer: IKEA of Sweden
          model: SOMRIG shortcut button
          multiple: false
    light:
      description: The light(s) to control
      selector:
          entity:
            domain: light
    force_brightness:
      name: Force turn on brightness
      description:
        Force the brightness to the set level below, when the "on" button
        on the remote is pushed and lights turn on.
      default: false
      selector:
        boolean: null
    brightness:
      description: Brightness of the light(s) when turning on
      default: 50
      selector:
        number:
          min: 0.0
          max: 100.0
          mode: slider
          step: 1.0
          unit_of_measurement: "%"
    hold_time:
      description: Time between the execution of the brighter/darker actions when holding the brighter/darker button.
      default: 0.5
      selector:
        number:
          min: 0.1
          max: 2
          step: 0.1
          unit_of_measurement: seconds
    single_dot_double_press:
      name: Single dot (Double press)
      description: Action to run on single dot double press
      default: []
      selector:
        action: {}
    double_dot_double_press:
      name: Double dot (Double press)
      description: Action to run on double dot double press
      default: []
      selector:
        action: {}
mode: restart
max_exceeded: silent
variables:
  force_brightness: !input "force_brightness"
  - platform: event
    event_type: zha_event
    event_data:
      device_id: !input "remote"
  - variables:
      command: "{{ trigger.event.data.command }}"
      cluster_id: "{{ trigger.event.data.cluster_id }}"
      endpoint_id: "{{ trigger.event.data.endpoint_id }}"
      args: "{{ trigger.event.data.args }}"
  - choose:
      - conditions:
          - "{{ command == 'short_release' }}"
          - "{{ endpoint_id == 1 }}"
        sequence:
          - choose:
              - conditions: "{{ force_brightness }}"
                sequence:
                  - service: light.turn_on
                    target: !input "light"
                      transition: 1
                      brightness_pct: !input "brightness"
            default:
                  transition: 1
      - conditions:
          - "{{ endpoint_id == 2 }}"
        sequence:
          - service: light.turn_off
              transition: 1
      - conditions:
          - "{{ command == 'long_press' }}"
        sequence:
          - repeat:
              count: 10
              sequence:
                    brightness_step_pct: 10
                    transition: !input "hold_time"
                - delay: !input "hold_time"
      - conditions:
        sequence:
          - repeat:
              count: 10
              sequence:
                    brightness_step_pct: -10
      - conditions:
         - '{{ command == ''multi_press_complete'' }}'
         - '{{ endpoint_id == 1 }}'
        sequence: !input single_dot_double_press
      - conditions:
         - '{{ endpoint_id == 2 }}'
        sequence: !input double_dot_double_press
I needed to add a parameter for the initial color temperature. I created an automation based on your blueprint. Would you find the time to add options for Force turn on temperature and Color of the light(s) when turning on? Here is the my fully working automation code:
alias: Kitchen table
description: ""
triggers:
  - event_type: zha_event
    event_data:
      device_id: 80630a2a1f3a8aceb61caadc3c8042ca
    trigger: event
actions:
  - variables:
  - choose:
      - conditions:
          - condition: template
            value_template: "{{ command == 'short_release' and endpoint_id == 1 }}"
        sequence:
          - target:
              entity_id: light.ikea_tradfri_bulb_gu10_ws_345lm_light
              transition: 0
              brightness_pct: "{{ initial_brightness }}"
              kelvin: "{{ initial_color_temp }}"
            action: light.turn_on
      - conditions:
            value_template: "{{ command == 'short_release' and endpoint_id == 2 }}"
        sequence:
          - target:
            data: {}
            action: light.turn_off
      - conditions:
            value_template: "{{ command == 'long_press' and endpoint_id == 1 }}"
        sequence:
          - repeat:
              count: 10
              sequence:
                - target:
                    transition: 0.5
                - delay: 0.5
      - conditions:
            value_template: "{{ command == 'long_press' and endpoint_id == 2 }}"
        sequence:
          - repeat:
              count: 10
              sequence:
                - target:
                    transition: 0.5
                - delay: 0.5
      - conditions:
            value_template: "{{ command == 'multi_press_complete' and endpoint_id == 1 }}"
        sequence:
          - target:
              kelvin: 2700
      - conditions:
            value_template: "{{ command == 'multi_press_complete' and endpoint_id == 2 }}"
        sequence:
          - target:
              kelvin: 2350
mode: restart
variables:
  initial_brightness: 90
  initial_color_temp: 4000
The biggest challenge was to ensure that pressing the single dot always turns on the light with the defined initial parameters. I finally succeeded.
I’m asking about the modification of the blueprint because the initial temperature might be useful for someone else as well. My attempts to create a blueprint always ended in syntax errors. In the end, I gave up.
Cheers :raising_hand_man:
