This blueprint is inspired from https://github.com/niro1987/homeassistant-config/blob/9b749e5283b9a797119972c0f28e0cea1df3e43a/blueprints/automation/niro1987/zha_ikea_tradfri_5button_remote_color.yaml
Commands:
Button
Action
Dim-Up
Turn on light at brightness: 100 and color_temp: 450
Dim-Down
Turn off
Dim-Up-holld
Increase brightness
Dim-Down-hold
Decrease brightness
Right
Change color
Left
Change saturation
Note: up+left switches light to white
simatao
October 13, 2022, 10:47pm
2
Cool thanks! How can I use this remote with a simple tradfri lamp that has just 3 different color temperatures (yellow, neutral, white)?
I’m also facing this issue, I haven’t found any working blueprint for it. I might make one soon tho, if none is available in the near future.
@Roeloyo10 Hi there, I was wondering if you ever got this working?
MrGlad8
(Andree)
November 30, 2024, 3:16pm
5
Heya, works fine! Would it be possible to change that “on” / dim-up to something other than its default? Its very dark every time you turn the light on!
