ZHA - Inovelli Blue Series Animated Notifications to single or multiple switches simultaneously!
Blueprint for Inovelli Blue Series (Model VZM31-SN) switches, using the LED bar to send animated notification effects to individual or multiple switches at the same time using ZHA.
When invoking the script, use the target selector for Areas containing switches or specific Devices/Entities.
Credits to @zanix and @nwithan8 as both blueprints were used as a base to this one.
blueprint:
  name: "Inovelli Blue VZM31-SN - Animated Notifications (ZHA)"
  description: |
    Credits to @zanix and @nwithan8 as both their blueprints were used as a base to this one
  domain: script
  source_url: https://github.com/dmoralesdev/homeassistant/blob/main/blueprints/inovelli_animated_notifications_ZHA.yaml
fields:
    description: Inovelli devices, entities, and/or areas with Inovelli devices to set effects.
    selector:
        device:
          integration: zha
          manufacturer: Inovelli
        entity:
          integration: zha
          domain: light
  led:
    description: Choose which LED to control. Default is All.
    default: All
    selector:
      select:
        custom_value: true
        options:
          - All
          - Led 1
          - Led 2
          - Led 3
          - Led 4
          - Led 5
          - Led 6
          - Led 7
  color:
    default: Red
    selector:
      select:
        custom_value: true
        options:
          - Red
          - Orange
          - Yellow
          - Green
          - Cyan
          - Teal
          - Blue
          - Purple
          - Light Pink
          - Pink
          - White
  level:
    description: Value from 0 (off) to 100 (100% brightness).
    default: 100
    example: "40"
    selector:
      number:
        min: 0
        max: 100
  effect:
    description: Choose LED effect to apply.
    default: Fast Blink
    selector:
      select:
        custom_value: true
        options:
          - "Off"
          - "Clear"
          - "Solid"
          - "Slow Blink"
          - "Medium Blink"
          - "Fast Blink"
          - "Pulse"
          - "Aurora"
          - "Slow Falling"
          - "Medium Falling"
          - "Fast Falling"
          - "Slow Rising"
          - "Medium Rising"
          - "Fast Rising"
          - "Slow Siren"
          - "Fast Siren"
          - "Chase"
          - "Slow Chase"
          - "Medium Chase"
          - "Fast Chase"
          - "Open-Close"
          - "Small-Big"
  duration:
    description: How long should the effect run?
    default: 10 Seconds
    selector:
      select:
        custom_value: true
        options:
          - 1 Second
          - 2 Seconds
          - 3 Seconds
          - 4 Seconds
          - 5 Seconds
          - 6 Seconds
          - 7 Seconds
          - 8 Seconds
          - 9 Seconds
          - 10 Seconds
          - 15 Seconds
          - 20 Seconds
          - 25 Seconds
          - 30 Seconds
          - 35 Seconds
          - 40 Seconds
          - 45 Seconds
          - 50 Seconds
          - 55 Seconds
          - 1 Minute
          - 2 Minutes
          - 3 Minutes
          - 4 Minutes
          - 5 Minutes
          - 6 Minutes
          - 7 Minutes
          - 8 Minutes
          - 9 Minutes
          - 10 Minutes
          - 15 Minutes
          - 20 Minutes
          - 25 Minutes
          - 30 Minutes
          - 35 Minutes
          - 40 Minutes
          - 45 Minutes
          - 50 Minutes
          - 55 Minutes
          - 1 Hour
          - 2 Hours
          - 3 Hours
          - 4 Hours
          - 5 Hours
          - 6 Hours
          - 7 Hours
          - 8 Hours
          - 9 Hours
          - 10 Hours
          - 15 Hours
          - 20 Hours
          - 1 Day
          - 2 Days
          - 3 Days
          - 4 Days
          - 5 Days
          - Indefinitely
  enable_debug:
    name: Enable debug output?
    selector:
      boolean:
variables:
  # Set to true to create a "persistent_notification" with debugging information.
  debug: "{{ iif(enable_debug is defined, enable_debug, false) }}"
  # Create a list of provided targets (areas, devices, entities)
  target: "{{ target|default([])|map(lower) }}"
  area: "{{ target.area_id|default([])|lower }}"
  device: "{{ target.device_id|default([])|lower }}"
  entity: "{{ target.entity_id|default([])|lower }}"
  entity_list: >
    {% set switch = namespace(entities=[]) %}
    {# Areas #}
    {% set areas = namespace(areas=[]) %}
    {% if area %}
      {# Convert to a list #}
      {% if ',' in area %}
        {% set areanum = area.split(',') | count %}
        {% for i in range(0,areanum) %}
          {% set areas.areas = areas.areas + [area.split(',')[i]|string|trim ] %}
        {% endfor %}
      {% elif area[0]|count == 1 %}
        {# if the first item in the list has only a single character, it can't be a valid entity #}
        {% set areas.areas = areas.areas + [area|string|trim] %}
      {% else %}
        {% set areas.areas = area %}
      {% endif %}
      {# Detect switches #}
      {% for area in areas.areas %}
        {% for ent in area_entities(area) %}
          {% if is_device_attr(ent, 'model', 'VZM31-SN') and ent.split('.')[0] == 'light' %}
            {% set switch.entities = switch.entities + [ent|string|trim] %}
          {% endif %}
        {% endfor %}
      {% endfor %}
    {% endif %}
    {# Devices #}
    {% set devices = namespace(devices=[]) %}
    {% if device %}
      {% if ',' in device %}
        {% set devicenum = device.split(',') | count %}
        {% for i in range(0,devicenum) %}
          {% set devices.devices = devices.devices + [device.split(',')[i]|string|trim ] %}
        {% endfor %}
      {% elif device[0]|count == 1 %} {# if the first item in the list has only a single character, it can't be a valid entity #}
        {% set devices.devices = devices.devices + [device|string|trim] %}
      {% else %}
        {% set devices.devices = device %}
      {% endif %}
      {% for device in devices.devices %}
        {% for ent in device_entities(device) %}
          {% endif %}
        {% endfor %}
      {% endfor %}
    {% endif %}
    {# Entities #}
    {% set entities = namespace(entities=[]) %}
    {% if entity %}
      {% if ',' in entity %}
        {% set entitynum = entity.split(',') | count %}
        {% for i in range(0, entitynum) %}
          {% set entities.entities = entities.entities + [entity.split(',')[i]|string|trim ] %}
        {% endfor %}
      {% elif entity[0]|count == 1 %} {# if the first item in the list has only a single character, it can't be a valid entity #}
        {% set entities.entities = entities.entities + [entity|string|trim] %}
      {% else %}
        {% set entities.entities = entity %}
      {% endif %}
      {% for ent in entities.entities %}
        {% endif %}
      {% endfor %}
    {% endif %}
    {{ switch.entities|unique|list|lower }}
  # Convert LED number to value
  leds:
    "all": -1
    "led 1": 0
    "led 2": 1
    "led 3": 2
    "led 4": 3
    "led 5": 4
    "led 6": 5
    "led 7": 6
  led: '{{ led|default("all") }}'
  led_value: >-
    {% if led|int(default=-2) == -2 %}
      {{ leds[led|lower]|int(default=-1) }}
    {% else %}
      {{ led|int(default=-1) }}
    {% endif %}
  level: "{{ level|default(100) }}"
  # Convert Color to value
  colors:
    "red": 1
    "orange": 21
    "yellow": 42
    "green": 85
    "cyan": 127
    "teal": 145
    "blue": 170
    "purple": 195
    "light pink": 220
    "lightpink": 220
    "pink": 234
    "white": 255
  color: '{{ color|default("red") }}'
  color_value: >-
    {% if color|int(default=-1) == -1 %}
      {{ colors[color|lower]|int(default=1) }}
    {% else %}
      {{ color|int(default=1) }}
    {% endif %}
  # Convert Effect to value
  effects:
    "off": 0
    "clear": 255
    "solid": 1
    "slow blink": 3
    "medium blink": 15
    "fast blink": 2
    "pulse": 4
    "aurora": 8
    "slow falling": 9
    "medium falling": 10
    "fast falling": 11
    "slow rising": 12
    "medium rising": 13
    "fast rising": 14
    "chase": 5
    "slow chase": 16
    "medium chase": 5
    "fast chase": 17
    "fast siren": 18
    "slow siren": 19
    "open-close": 6
    "small-big": 7
  effect: '{{ effect|default("fast blink") }}'
  effect_value: >-
    {% if effect|lower in effects %}
      {{ effects[effect|lower] }}
    {% else %}
      {{ effect|lower }}
    {% endif %}
  # Convert Duration to value
  durations:
    "1 second": 1
    "2 seconds": 2
    "3 seconds": 3
    "4 seconds": 4
    "5 seconds": 5
    "6 seconds": 6
    "7 seconds": 7
    "8 seconds": 8
    "9 seconds": 9
    "10 seconds": 10
    "15 seconds": 15
    "20 seconds": 20
    "25 seconds": 25
    "30 seconds": 30
    "35 seconds": 35
    "40 seconds": 40
    "45 seconds": 45
    "50 seconds": 50
    "55 seconds": 55
    "1 minute": 60
    "2 minutes": 62
    "3 minutes": 63
    "4 minutes": 64
    "5 minutes": 65
    "6 minutes": 66
    "7 minutes": 67
    "8 minutes": 68
    "9 minutes": 69
    "10 minutes": 70
    "15 minutes": 75
    "20 minutes": 80
    "25 minutes": 85
    "30 minutes": 90
    "35 minutes": 95
    "40 minutes": 100
    "45 minutes": 105
    "50 minutes": 110
    "55 minutes": 115
    "1 hour": 120
    "2 hours": 122
    "3 hours": 123
    "4 hours": 124
    "5 hours": 125
    "6 hours": 126
    "7 hours": 127
    "8 hours": 128
    "9 hours": 129
    "10 hours": 130
    "15 hours": 135
    "20 hours": 140
    "1 day": 144
    "2 days": 168
    "3 days": 192
    "4 days": 216
    "5 days": 240
    "indefinitely": 255
  duration: '{{ duration|default("10 seconds") }}'
  duration_value: >-
    {% if duration|int(default=-1) == -1 %}
      {{ durations[duration|lower]|int(default=10) }}
    {% else %}
      {{ duration|int(default=10) }}
    {% endif %}
sequence:
  # Set enable_debug = true above to provide output troubleshooting information.
  - if:
      - condition: template
        value_template: "{{ debug == true }}"
    then:
      - service: persistent_notification.create
          notification_id: "inovelli_animated"
          title: "DEBUG: inovelli_animated"
          message: |-
            entity list: {{ entity_list }}
            entity count: {{ entity_list|count }}
            led: {{ led }} ({{ led_value }})
            color: {{ color }} ({{ color_value }})
            level: {{ level }}
            effect: {{ effect }} ({{ effect_value }})
            duration: {{ duration }} ({{ duration_value }})
  # Do not continue if we don't have at least one entity
    value_template: |
      {{ entity_list|count > 0 }}
  - variables:
      # Construct the payload
      payload: |-
        {% if led_value == -1 %}
          {% set payload_data = {
            "led_effect": effect_value,
            "led_color": color_value,
            "led_level": level,
            "led_duration": duration_value,
        {% else %}
            "led_number": led_value,
            "led_level": level,
        {% endif %}
        {{ payload_data }}
  # Loop through entity_list
  - repeat:
      for_each: "{{ entity_list }}"
      sequence:
        - if:
          then:
                notification_id: "inovelli_animated::{{ repeat.item }}"
                title: "DEBUG: inovelli_animated::{{ repeat.item }}"
                message: |-
                  entity: {{ repeat.item }}
                  device name: {{ device_attr(repeat.item, "name") }}
                  IEEE: {{ (device_attr(repeat.item, "identifiers")|list).0.1 }}
                  payload: {{ payload }}
        - service: zha.issue_zigbee_cluster_command
            ieee: >
            endpoint_id: 1
            cluster_id: 64561
            cluster_type: in
            command: >
              {{ iif(led_value == -1, 1, 3) }}
            command_type: server
            params: "{{ payload }}"
            manufacturer: 4655
icon: mdi:led-on
mode: parallel
max_exceeded: silent
max: 100
Nice, learned some new things here that I might adopt
Hey this was exactly what I was looking for with my switches. Thanks so much for creating it!
@diegomorales17 thanks for sharing this script.
I’m still in the process of getting familiar with HA and my Inovelli switches. But I have found that this script will not work for me if I select more than one target. I get a timeout error in the UI. I see the following logged to the ha log.
File "/usr/src/homeassistant/homeassistant/core.py", line 2104, in _execute_service
    return await target(service_call)
  File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 986, in admin_handler
    await result
  File "/usr/src/homeassistant/homeassistant/components/zha/websocket_api.py", line 1361, in issue_zigbee_cluster_command
    await zha_device.issue_cluster_command(
  File "/usr/src/homeassistant/homeassistant/components/zha/core/device.py", line 820, in issue_cluster_command
    response = await getattr(cluster, commands[command].name)(
  File "/usr/local/lib/python3.11/site-packages/zigpy/quirks/__init__.py", line 199, in command
    return await self.request(
  File "/usr/local/lib/python3.11/site-packages/zigpy/zcl/__init__.py", line 377, in request
    return await self._endpoint.request(
  File "/usr/local/lib/python3.11/site-packages/zigpy/endpoint.py", line 253, in request
    return await self.device.request(
  File "/usr/local/lib/python3.11/site-packages/zigpy/device.py", line 315, in request
    async with asyncio_timeout(timeout):
  File "/usr/local/lib/python3.11/asyncio/timeouts.py", line 111, in __aexit__
    raise TimeoutError from exc_val
TimeoutError
Any hints on what I could track down to see if I can help fix this?
Wanted to follow up on my own post here to say that I was able to resolve this with a firmware upgrade to my Inovelli Blue switches. Discovered that my new switches were running firmware version 2.0. After an upgrade to firmware version 2.15, these (as well as many other) issues are resolved.
Thanks again for sharing this script @diegomorales17
I modified this script to include support for HA labels, in case anybody is interested. It currently relies on the label devices (not entities) but I could easily update it to support either, if anybody is interested in that (I only specify the devices for these switches, personally).
First time sharing a blueprint, so bear with me while I try to figure out how…
blueprint:
  description: |
    When invoking the script, use the target selector for Areas or Labels containing switches or specific Devices/Entities.
    Credits to @dmoralesdev and @zanix and @nwithan8 as both their blueprints were used as a base to this one
  domain: script
  source_url: https://github.com/dmoralesdev/homeassistant/blob/98cde2356f7a00fdc0640add3e2e7c48b72c4114/blueprints/inovelli_animated_notifications_ZHA.yaml
fields:
    selector:
        device:
          integration: zha
        entity:
          integration: zha
          domain: light
  led:
    default: All
    selector:
      select:
        custom_value: true
        options:
          - All
          - Led 1
          - Led 2
          - Led 3
          - Led 4
          - Led 5
          - Led 6
          - Led 7
  color:
    default: Red
    selector:
      select:
        custom_value: true
        options:
          - Red
          - Orange
          - Yellow
          - Green
          - Cyan
          - Teal
          - Blue
          - Purple
          - Light Pink
          - Pink
          - White
  level:
    default: 100
    example: "40"
    selector:
      number:
        min: 0
        max: 100
  effect:
    default: Fast Blink
    selector:
      select:
        custom_value: true
        options:
          - "Off"
          - "Clear"
          - "Solid"
          - "Slow Blink"
          - "Medium Blink"
          - "Fast Blink"
          - "Pulse"
          - "Aurora"
          - "Slow Falling"
          - "Medium Falling"
          - "Fast Falling"
          - "Slow Rising"
          - "Medium Rising"
          - "Fast Rising"
          - "Slow Siren"
          - "Fast Siren"
          - "Chase"
          - "Slow Chase"
          - "Medium Chase"
          - "Fast Chase"
          - "Open-Close"
          - "Small-Big"
  duration:
    default: 10 Seconds
    selector:
      select:
        custom_value: true
        options:
          - 1 Second
          - 2 Seconds
          - 3 Seconds
          - 4 Seconds
          - 5 Seconds
          - 6 Seconds
          - 7 Seconds
          - 8 Seconds
          - 9 Seconds
          - 10 Seconds
          - 15 Seconds
          - 20 Seconds
          - 25 Seconds
          - 30 Seconds
          - 35 Seconds
          - 40 Seconds
          - 45 Seconds
          - 50 Seconds
          - 55 Seconds
          - 1 Minute
          - 2 Minutes
          - 3 Minutes
          - 4 Minutes
          - 5 Minutes
          - 6 Minutes
          - 7 Minutes
          - 8 Minutes
          - 9 Minutes
          - 10 Minutes
          - 15 Minutes
          - 20 Minutes
          - 25 Minutes
          - 30 Minutes
          - 35 Minutes
          - 40 Minutes
          - 45 Minutes
          - 50 Minutes
          - 55 Minutes
          - 1 Hour
          - 2 Hours
          - 3 Hours
          - 4 Hours
          - 5 Hours
          - 6 Hours
          - 7 Hours
          - 8 Hours
          - 9 Hours
          - 10 Hours
          - 15 Hours
          - 20 Hours
          - 1 Day
          - 2 Days
          - 3 Days
          - 4 Days
          - 5 Days
          - Indefinitely
  enable_debug:
    selector:
      boolean:
variables:
  label: "{{ target.label_id|default([])|lower }}"
  entity_list: >
      {# Labels #} {% set labels = namespace(labels=[]) %} {% if label %}
      {% if ',' in label %}
        {% set labelnum = label.split(',') | count %}
        {% for i in range(0,labelnum) %}
          {% set labels.labels = labels.labels + [label.split(',')[i]|string|trim ] %}
        {% endfor %}
      {% elif label[0]|count == 1 %}
        {% set labels.labels = labels.labels + [label|string|trim] %}
      {% else %}
        {% set labels.labels = label %}
      {% endif %}
      {% for label in labels.labels %}
        {% for device in label_devices(label) %}
            {% endif %}
          {% endfor %}
        {% endfor %}
      {% endfor %}
    {% endif %}
    {# Areas #}
    {% if area %}
        {% endfor %}
      {% else %}
      {% endif %}
          {% endif %}
        {% endfor %}
      {% endfor %}
    {% endif %}
    {# Devices #}
    {% if device %}
        {% endfor %}
      {% else %}
      {% endif %}
          {% endif %}
        {% endfor %}
      {% endfor %}
    {% endif %}
    {# Entities #}
    {% if entity %}
        {% endfor %}
      {% else %}
      {% endif %}
        {% endif %}
      {% endfor %}
    {% endif %}
  leds:
    "all": -1
    "led 1": 0
    "led 2": 1
    "led 3": 2
    "led 4": 3
    "led 5": 4
    "led 6": 5
    "led 7": 6
  led_value: >-
    {% else %}
    {% endif %}
  colors:
    "red": 1
    "orange": 21
    "yellow": 42
    "green": 85
    "cyan": 127
    "teal": 145
    "blue": 170
    "purple": 195
    "light pink": 220
    "lightpink": 220
    "pink": 234
    "white": 255
  color_value: >-
    {% else %}
    {% endif %}
  effects:
    "off": 0
    "clear": 255
    "solid": 1
    "slow blink": 3
    "medium blink": 15
    "fast blink": 2
    "pulse": 4
    "aurora": 8
    "slow falling": 9
    "fast falling": 11
    "slow rising": 12
    "medium rising": 13
    "fast rising": 14
    "chase": 5
    "slow chase": 16
    "medium chase": 5
    "fast chase": 17
    "fast siren": 18
    "slow siren": 19
    "open-close": 6
    "small-big": 7
  effect_value: >-
    {% else %}
      {{ effect|lower }}
    {% endif %}
  durations:
    "1 second": 1
    "2 seconds": 2
    "3 seconds": 3
    "4 seconds": 4
    "5 seconds": 5
    "6 seconds": 6
    "7 seconds": 7
    "8 seconds": 8
    "9 seconds": 9
    "10 seconds": 10
    "15 seconds": 15
    "20 seconds": 20
    "25 seconds": 25
    "30 seconds": 30
    "35 seconds": 35
    "40 seconds": 40
    "45 seconds": 45
    "50 seconds": 50
    "55 seconds": 55
    "1 minute": 60
    "2 minutes": 62
    "3 minutes": 63
    "4 minutes": 64
    "5 minutes": 65
    "6 minutes": 66
    "7 minutes": 67
    "8 minutes": 68
    "9 minutes": 69
    "10 minutes": 70
    "15 minutes": 75
    "20 minutes": 80
    "25 minutes": 85
    "30 minutes": 90
    "35 minutes": 95
    "40 minutes": 100
    "45 minutes": 105
    "50 minutes": 110
    "55 minutes": 115
    "1 hour": 120
    "2 hours": 122
    "3 hours": 123
    "4 hours": 124
    "5 hours": 125
    "6 hours": 126
    "7 hours": 127
    "8 hours": 128
    "9 hours": 129
    "10 hours": 130
    "15 hours": 135
    "20 hours": 140
    "1 day": 144
    "2 days": 168
    "3 days": 192
    "4 days": 216
    "5 days": 240
    "indefinitely": 255
  duration_value: >-
    {% else %}
    {% endif %}
sequence:
  - if:
    then:
          message: |-
            level: {{ level }}
    value_template: |
  - variables:
      payload: |-
            "led_level": level,
        {% else %}
            "led_level": level,
        {% endif %}
        {{ payload_data }}
  - repeat:
      sequence:
        - if:
          then:
                message: |-
            ieee: >
            endpoint_id: 1
            cluster_id: 64561
            cluster_type: in
            command: >
            manufacturer: 4655
icon: mdi:led-on
mode: parallel
max: 100
Has anyone else noticed that this script seems to have stopped working after a recent HA update? I am now only getting one switch out of the group that will display the notification. No other changes but HA updates on my end.
… So does this not work anymore or am I going crazy.
My issue was that one of the switches in the group assigned to this script was taken out of service, so apparently when the script came along to the missing entity, it failed to activate any other switches. So issue was on my end.
If anyone here is interested in an integration instead of a blueprint, I created something similar recently: Lampie: Notifications on Multiple Inovelli Switches.
(Or if this blueprint stopped working as some have reported.)
Hello I have been using this blueprint for a while and recently I tried something new with it. I set a effect duration to indefinitely. The problem I am running into is how do I stop the effect. Script turn off does not work as well as running the script again with different setting. Is there a way to stop it?
It looks like this blueprint might not be maintained anymore. The original poster hasn't replied in awhile. I have a similar blueprint that you might want to try: Control LEDs and LED Effects on Inovelli Black, Red, Blue, and White Series Devices by Floor, Area, Group, Device ID, or Entity
