This is an adaptation of @fxlt’s fantastic [ZHA] Inovelli VZM31-SN Blue Series 2-1 Switch blueprint to support the new Inovelli Blue Series Fan Switch (VZM35-SN), codenamed “Zephyr.” As with the original blueprint, it supports ZHA.
blueprint:
name: "Inovelli VZM35-SN Blue Series Fan Switch (ZHA)"
description: Create automations for the Inovelli VZM35-SN using ZHA.
domain: automation
input:
inovelli_switch:
description: "List of available Inovelli VZM35-SN switches."
selector:
device:
integration: zha
manufacturer: Inovelli
model: VZM35-SN
## Pressed Once
button_1:
name: Down paddle pressed
description: "Action to run when down paddle is pressed once."
default: []
selector:
button_2:
name: Up paddle pressed
description: "Action to run when up paddle is pressed once."
default: []
selector:
button_3:
name: Config button pressed
description: "Action to run when config button is pressed once."
default: []
selector:
## Held
button_1_hold:
name: Down paddle held
description: "Action to run when down paddle is held."
default: []
selector:
button_2_hold:
name: Up paddle held
description: "Action to run when up paddle is held."
default: []
selector:
button_3_hold:
name: Config button held
description: "Action to run when config button is held."
default: []
selector:
## Released
button_1_release:
name: Down paddle released
description: "Action to run when down paddle is released."
default: []
selector:
button_2_release:
name: Up paddle released
description: "Action to run when up paddle is released."
default: []
selector:
button_3_release:
name: Config button released
description: "Action to run when config button is released."
default: []
selector:
## Pressed Twice
button_1_double:
name: Down paddle pressed twice
description: "Action to run when down paddle is pressed twice."
default: []
selector:
button_2_double:
name: Up paddle pressed twice
description: "Action to run when up paddle is pressed twice."
default: []
selector:
button_3_double:
name: Config button pressed twice
description: "Action to run when config button is pressed twice."
default: []
selector:
## Pressed Thrice
button_1_triple:
name: Down paddle pressed three times
description: "Action to run when down paddle is pressed three times."
default: []
selector:
button_2_triple:
name: Up paddle pressed three times
description: "Action to run when up paddle is pressed three times."
default: []
selector:
button_3_triple:
name: Config button pressed three times
description: "Action to run when config button is pressed three times."
default: []
selector:
## Pressed Four Times
button_1_quadruple:
name: Down paddle pressed four times
description: "Action to run when down paddle is pressed four times."
default: []
selector:
button_2_quadruple:
name: Up paddle pressed four times
description: "Action to run when up paddle is pressed four times."
default: []
selector:
button_3_quadruple:
name: Config button pressed four times
description: "Action to run when config button is pressed four times."
default: []
selector:
## Pressed Five Times
button_1_quintuple:
name: Down paddle pressed five times
description: "Action to run when down paddle is pressed five times."
default: []
selector:
button_2_quintuple:
name: Up paddle pressed five times
description: "Action to run when up paddle is pressed five times."
default: []
selector:
button_3_quintuple:
name: Config button pressed five times
description: "Action to run when config button is pressed five times."
default: []
selector:
mode: single
max_exceeded: silent
variables:
device_id: !input "inovelli_switch"
- platform: event
event_type: zha_event
condition: "{{ trigger.event.data.device_id == device_id }}"
- variables:
command: '{{ trigger.event.data.command }}'
- service: "logbook.log"
message: 'received event: {{ command }}'
- choose:
### Button 1 (Down Paddle)
- conditions: "{{ command == 'button_1_press' }}"
sequence: !input button_1
- conditions: "{{ command == 'button_1_hold' }}"
sequence: !input button_1_hold
- conditions: "{{ command == 'button_1_release' }}"
sequence: !input button_1_release
- conditions: "{{ command == 'button_1_double' }}"
sequence: !input button_1_double
- conditions: "{{ command == 'button_1_triple' }}"
sequence: !input button_1_triple
- conditions: "{{ command == 'button_1_quadruple' }}"
sequence: !input button_1_quadruple
- conditions: "{{ command == 'button_1_quintuple' }}"
sequence: !input button_1_quintuple
### Button 2 (Upper Paddle)
- conditions: "{{ command == 'button_2_press' }}"
sequence: !input button_2
- conditions: "{{ command == 'button_2_hold' }}"
sequence: !input button_2_hold
- conditions: "{{ command == 'button_2_release' }}"
sequence: !input button_2_release
- conditions: "{{ command == 'button_2_double' }}"
sequence: !input button_2_double
- conditions: "{{ command == 'button_2_triple' }}"
sequence: !input button_2_triple
- conditions: "{{ command == 'button_2_quadruple' }}"
sequence: !input button_2_quadruple
- conditions: "{{ command == 'button_2_quintuple' }}"
sequence: !input button_2_quintuple
### Button 3 (Config Button)
- conditions: "{{ command == 'button_3_press' }}"
sequence: !input button_3
- conditions: "{{ command == 'button_3_hold' }}"
sequence: !input button_3_hold
- conditions: "{{ command == 'button_3_release' }}"
sequence: !input button_3_release
- conditions: "{{ command == 'button_3_double' }}"
sequence: !input button_3_double
- conditions: "{{ command == 'button_3_triple' }}"
sequence: !input button_3_triple
- conditions: "{{ command == 'button_3_quadruple' }}"
sequence: !input button_3_quadruple
- conditions: "{{ command == 'button_3_quintuple' }}"
sequence: !input button_3_quintuple
Note: There’s a bug with the ZHA quirk for this switch which prevents button press events from being fired. Inovelli has a fix and it should hopefully be deployed soon. I’ve confirmed that this blueprint works with the fix.
